How do I remove the ABS unit? I got the moduke out
Old Jul 8, 2012 | 04:19 PM
Chicago1's Avatar
Chicago1
Default How do I remove the ABS unit? I got the module out
This is for a 2001. Well I followed the how to on getting the module out which was pretty simple but would like a how to on the pump itself. Let me know if there are any links. I did a title search for "abs pump removal" and not 1 thread on it, thanks
Old Jul 8, 2012 | 05:06 PM
TheWildcat's Avatar
TheWildcat
just make sure you havea TECH2 to blead it when you get it changed..John
Old Jul 8, 2012 | 05:07 PM
Chicago1's Avatar
Chicago1
Crap I was hoping for a plug and play. Guess I can add that to the list. thanks John
Edit: Maybe when I get that pump I should just swap the module out since my old pump was technicaly good and I'm just really need just the module..
Old Jul 8, 2012 | 05:37 PM
Oleman's Avatar
Oleman
Are you just replacing the module? If so you can repair those or replace them.
Old Jul 8, 2012 | 05:44 PM
Chicago1's Avatar
Chicago1
As the title says and my post says I have the module out. I want to know how to get the pump out. Everything I search for is just to get the module out nothing about the pump. That's the easy part was the module . I messed up my module and have a new pump and module coming so I figured I might as well replace both.
To How do I remove the ABS unit? I got the moduke out
