Need a T-500 Torex.. ????!!??!?
Old May 27, 2002 | 05:03 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Need a T-500 Torex.. ????!!??!?
HI, I need a T-500 Torex to remove the seat belt bolts. Anyone have one that I can borrow, or know where I can buy one? I can't find a T-500 at pep boy, etc... I tried a t-50 and that worked on 3 of the 4 but the last one won't budge and I don't want to damage the bolt.
[Modified by Bluewasp, 4:07 PM 5/27/2002]
Old May 27, 2002 | 06:03 PM
YELLOHHH's Avatar
YELLOHHH
Default Re: Need a T-500 Torex.. ????!!??!? (Bluewasp)
I bought my torx set at Sears. Check there. If you want to drive to Silver Spring, you can borrow mine.
Greg
:cool:
Old May 27, 2002 | 07:32 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: Need a T-500 Torex.. ????!!??!? (YELLOHHH)
Thanks!! I was able to get my hands on one..
http://buy.snapon.com/catalog/search...e=snapon-store
Old May 27, 2002 | 07:35 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I picked up a sears t-50 since they don't carry a t-500 / "T-50 GM size"
Snap-on Tools does if anyone needs one.
Why can't GM use a "normal" T-50? They have to make it difficult and create their own T-50 Size
[Modified by Bluewasp, 6:38 PM 5/27/2002]
Old May 27, 2002 | 07:51 PM
LoneStarFRC's Avatar
LoneStarFRC
The Torx T-50 is an SAE standard size that's been around for years. Lots of tool manufacturers make it. Never heard of a "T-500". Where did you get that number? :confused:
Old May 27, 2002 | 08:50 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: Need a T-500 Torex.. ????!!??!? (Tx99FRC)
I got it from here:
and here:
http://www.bkauto.com/faqbmw.html
Corvette C5 & Z06 installation information: Model R-1115 fits both coupe & fixed roof models. Does not fit convertibles. Main bar attaches to shoulder belt mounting points in 'B" pillars. Anti-rotation support tubes run from main support bar to seat track mounting point. Support rods will not interfere with operation of the seats. Bar does not interfere with removable top when stowed away. Lap belt mounting kits are sold separately. The seam in the trim where the seat belt protrudes must be widened approximately 3/16" to accommodate mounting hardware for the outside lap belt mount kit. A T-500 socket is used to remove GM factory seat belt hardware. This tool is available from serveral popular tool manufactures. See T-500 Part# FTX47E socket with bit available from SNAP-ON TOOLS - 800.926.5544 EXT# -5566 or at http://www.snapon.com
Its also in a GM manual someplace...
Old May 27, 2002 | 08:57 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
A t-50 does'nt fit the bolt perfect....
Old May 28, 2002 | 11:38 AM
thekev_2000's Avatar
thekev_2000
I ran into this same problem finding one when installing my harness bar. Since I could not wait for one to be shipped, and since I was not reusing the seat belt bolts I took a hack approach and used an allen wrench.. :lol:. Worked fine to get them out and installed the Brey-Krause with no problems. Just a FYI in case anyone else needs to do this swap in a pinch.
Old May 28, 2002 | 04:47 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: Need a T-500 Torex.. ????!!??!? (thekev_2000)
I am so glad there is someone else that had the same problem!!! Every place I called about a T-500 told me I was wrong and I needed to use a T-50, etc. etc... GM :rolleyes:
Old May 30, 2002 | 08:31 PM
LoneStarFRC
What's really wierd to me is that the Brey-Krause site says "T-500" for both the C-4 and C-5 and then refers to the Snap-On part number FTX47E.
When you go to the Snap-On site, their own illustration and text refers to that part number as a T-50. I still can't figure out where the "T-500" number is coming from. Anybody? :confused:
Old May 30, 2002 | 09:42 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
No. Reread the snap-on site. Snap-on calls the torx "T-50/GM Style" There is a difference from a "T-50/GM Style" and a Normal SAE T-50. A normal T-50 from sears, pepboys, etc. Does NOT fit perfect. There is SOME play...
I heard GM named that size "T-500"
Robert
[Modified by Bluewasp, 8:51 PM 5/30/2002]
Old May 31, 2002 | 06:36 PM
LoneStarFRC
I did see the reference to "GM" T-50 in Snap-On's ad. I remember using a Torx when I removed my seat belt anchor bolts in the past and don't recall a problem. Oh well, maybe I just got lucky with mine and a regular T-50 worked. Maybe this "T-500" would be the SAE equivalent to a "T-51 or T-52" (if there was such a thing) :lol:
Thanks,
Robert
To Need a T-500 Torex.. ????!!??!?
