Automatic Shifter install help needed
Old Jul 13, 2012 | 03:56 PM
CHRIS COVE's Avatar
CHRIS COVE
Default Automatic Shifter install help needed
Looks like I need to replace the shifter assembly. I purchased a new one, removed the **** and center console. Before I go any further I was wondering what happens after I take off the 4 nuts that hold the shifter to the console. Does it just lift out? I don't want to pull it up then find out I can't put it back together. It seems like it only attaches at one point.
Thanks for any feedback
Old Jul 13, 2012 | 04:17 PM
bumble-z's Avatar
bumble-z
You haven't mentioned the reason for changing out the shifter assy?
Here is some reading that hopefully will walk you through.
Good luck.
http://forums.corvetteforum.com/c5-t...r-failure.html
Old Jul 13, 2012 | 06:57 PM
CHRIS COVE's Avatar
CHRIS COVE
A couple of days ago I noticed the shift lever became very loose and sloppy feeling when I shift into gear. I'm assuming a plastic gear or something is worn out. After taking the boot off I didn't see anything broke. Thanks for the link, looks like good reading.
To Automatic Shifter install help needed
