turn signals problems
Old Jul 14, 2012 | 07:50 AM
rcskisfast's Avatar
rcskisfast
Default turn signals problems
Recently my turn signals will not work I turn the signal on and the indicator lamps are not flashing this happens in either direction. When I put the 4 way flashers the indicators work. This problem is intermitten. Any Ideas? Thanks, Ron
Old Jul 14, 2012 | 08:20 AM
65GGvert's Avatar
65GGvert
Go to the C5 tech page (where you typed this thread) and on the right, select "search this forum". Type in "intermittent turn signals" and you will see several threads on how to either replace or bypass your four way flasher. Or you can just cycle it quickly off/on several times and the turn signals will work for a while.
Click here for one of them, but there are many more for your reading pleasure:
http://forums.corvetteforum.com/c5-t...t+turn+signals
Old Jul 14, 2012 | 08:46 AM
LagunaPete's Avatar
LagunaPete
Default Covered
This assures that you have a genuine Corvette and not some knock off . It is inherent in the C5 in other words.
Yes, 65GGvert is right. The forum totally covers it.
This is a classic example where the saying applies:
"If it works, don't fix it."
I get suspicions that when these designers come up with these outlandish setups like this one, that it is literally designed to fail. They make it for the parts department. That is what I think. Look. You're not going to incorporate all the electronics for signaling in a module that small, especially with consideration of the size of relay that's used.
Old Jul 16, 2012 | 07:02 PM
rcskisfast's Avatar
rcskisfast
I'm in total agreement, They developed drive by wire, in all my years dealing with throttle cables never had a problem with one. If you did it was less than 20 bucks to replace the cable. Now with drive by wire it will probably cost a min of 250.00 to fix. Sometime technoligy is overkill. Thanks everyone for your help I'll fix the problem. Regard's, Ron
To turn signals problems
