How do I get C5 to run cooler?
Old May 27, 2002 | 10:19 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
Default How do I get C5 to run cooler?
My 99 Coupe coolant runs between 185-200 degrees on the highway but runs at 220-230 around town and just idling. I have a low temp thermostat (180 I think) and the coolant level is OK. Any ideas???
Old May 27, 2002 | 10:22 PM
lostsoulny's Avatar
lostsoulny
Default Re: How do I get C5 to run cooler? (wickedvette)
you only have a low tstat if you put one in. You need to either get a hypertech or get someone to program it so it is set to utilize the tsat and kick on fans sooner. I am not a tech but hope this info gives you some help :seeya :chevy
Old May 27, 2002 | 11:33 PM
Sully C5's Avatar
Sully C5
We have a 170 Thermostat with Fan Controller & our temp stays below 200 in traffic.
Old May 27, 2002 | 11:34 PM
Hex29A's Avatar
Hex29A
My 99 Coupe coolant runs between 185-200 degrees on the highway but runs at 220-230 around town and just idling. I have a low temp thermostat (180 I think) and the coolant level is OK. Any ideas???Thanks
If you replaced your thermostat with a lower one, you need to re-program the fans to come on at the lower temperature.
I replaced my thermostat with a 178° a year ago without re-programming. I had similar result to yours. Cartek did a tuning reprogramming a few weeks ago and now the car is between 181° and 185° all the time.
Hope this helps
Old May 27, 2002 | 11:59 PM
wickedvette
Default Re: How do I get C5 to run cooler? (Hex29A)
What's the cheapest/easiest way to reprogram the fans??
Old May 28, 2002 | 12:11 AM
TomLzzz's Avatar
0TomLzzz
Former Vendor
Pick up a used Hypertech Programmer from someone here on the forum or on E-bay. I have bought 1 here and 2 on E-bay in the past with no problems.
Old May 28, 2002 | 12:20 AM
golfman's Avatar
golfman
St. Jude Donor '05
Turn the fans on sooner. I would think you could do this manuelly but I am not sure what wires to tap into. I have posted this question before with very little response. I see the ls1 camaro's guys have done this, so I know it can be done.
Old May 28, 2002 | 12:39 AM
aces's Avatar
aces
Default Re: How do I get C5 to run cooler? (golfman)
also get a real radiator ie. Be-Cool :cheers:
Old May 28, 2002 | 07:52 AM
EMDExpress's Avatar
EMDExpress
Default Re: How do I get C5 to run cooler? (aces)
See a tuner with LS1 Edit and have them set the fans to come on sooner. I had mine done when heads and can were installed. With the stock thermostat my H2O temp never gets above 192. Oil maxes out at 207. :yesnod: :yesnod: :yesnod: :lol: :lol: :lol: :lol: :lol: :seeya
To How do I get C5 to run cooler?
