C5 Active Handling Software Upgrade
For example, a 2000 and want the 2002 updates.
Anybody done that before?
Thanks,
D.
I recently had my car in to have the passenger window repaied. I asked them to check the PCM programing for updates. They did and flashed my PCM with the new software.. not sure what got updated.
mike
The update made the active handling and the traction control less sensitive and they recover more quickly. :cheers:
:cheers:
:cheers:
I had service done just for this issue.
The local dealer takes very good care of the Vetts, which are in for service.
This is the service bulliten covering the software update.
Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift
(Reprogram PCM) #02-06-04-001
Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift (Reprogram PCM)
2001 Chevrolet Corvette With 5.7L Engine (VIN G - RPO LS1)
Condition
Some customers may comment that the engine lacks power following a wide open throttle downshift, either 3-2 or 4-2, followed by a wide open throttle 2-3 upshift.
Correction
A new service calibration is available for this condition. This calibration is available from Techline starting September 2001, on the TIS 2000 version TIS 10/2001 data update or later. Reprogram the PCM with the new calibration.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
J6355 Powertrain Controller-- Reprogram 0.4 hr
