LS2 tbody
Old Jul 26, 2012 | 03:51 AM
Slammedc5..'s Avatar
Slammedc5..
Default LS2 tbody
Aloha gang,
I have an ls6 intake with a 90mm snout on the way. Other than the adaptor wiring harness and adjusting my tune. What else will I need to do to make it fit
Old Jul 26, 2012 | 08:59 AM
67ermine's Avatar
67ermine
Get ls2 85mm MAF, wiring adapter for that, silicone coupler, tune.
Old Jul 26, 2012 | 01:19 PM
Slammedc5..
Thanks man.
My car is an 01, so i already have the 85mm MAF. Descreened. I forgot I'll need a new couple. I already have a nice silicone one, wonder if I can strecth it.
Old Jul 26, 2012 | 01:57 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I have a FAST 92 install procedure on my web site. Check it over to see if there is anything you may be missing I forgot below.
www.ToqueZ06.com
Your going to need a LS2 TB cable
http://www.casperselectronics.com/st...oducts_id=1087
Your going to need a TB bypass because the LS2 TB does not have the cooling water passages thru it like the LS1 TB has.
your going to need to vent the valve cover somehow because the LS2 TB does not have the port that the LS1 TB has.
I got 4x 45mm #6 Stainless bolts with washers/lock washers to mount the TB to the intake.
Toque
Old Jul 26, 2012 | 03:08 PM
Slammedc5..
Default 85mm tyhoon
Tbody bypass already. Nice tip on the bolts. Will i have to stretch my silicone coupler?
Old Jul 26, 2012 | 05:37 PM
Toque's Avatar
Toque
My silicone coupler is the same one that I had connected to my LS6 TB.
I just put the hole in it for the air line when i installed my LS2 TB.
Don't forget the Casper harness I mentioned above too....
Toque
Old Jul 26, 2012 | 06:09 PM
Slammedc5..
Yep, thanks. I have it covered. Wonder if the harness works on 08 c6z tbody. The c6z says its an up grade for the ls2 tbody. I can grab a new tody off a 08 ls7 crate engine
To LS2 tbody
