Changed diff fluid today and I am concerned......
Old Jul 27, 2012 | 09:58 PM
crAzy's Avatar
crAzy
Default Changed diff fluid today and I am concerned......
I bought 2 qrts of oil for the rear diff. Didn't have a pump, but had a long tube and used the squeeze method. Well I was able to get all 2 qrts in without it over flowing from the fill hole. Also had a nozzle with butterfly wings to grip onto the threads so it doesn't back out of the hole. This is on a 03 Z06. Am I safe to drive it with both bottles 99% all the way in there?
Oh crap just realized when filling it I had it jacked up in the rear and the front on the ground. DOH!. Is it ok to over flow?
Old Jul 27, 2012 | 10:15 PM
pcbunn's Avatar
pcbunn
Old Jul 27, 2012 | 10:22 PM
crAzy's Avatar
crAzy
Ok tom morning I am going to undo the fill plug and hope some fluid drains out. The car will also be level when I do this. Can't believe I didn't even consider the car being slanted forward lol. I am an idiot.
Old Jul 27, 2012 | 10:26 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
With 2 quarts, it is definitely overfilled. Level the car, and allow the excess fluid to drain .
The correct fluid level is at the bottom of the filler plug hole. The fluid capacity is 1.69 quarts.
Old Jul 27, 2012 | 10:30 PM
crAzy's Avatar
crAzy
Well I did this at my dad's down the street since he has a huge workshop. I should be ok if I don't drive it to much or drive it hard. Drive like a grandma. But yes I will go tom morning and open the fill hole a little and let the fluid come out.
Old Jul 27, 2012 | 10:42 PM
pcbunn's Avatar
pcbunn
I'm glad I'm not the only idiot; I was repacking the front wheel bearings on my Ford Lighting and when removing the right front caliper I wondered why it was so hard to remove the mounting bolt,,until I realized I was pulling on it the wrong way!
Old Jul 27, 2012 | 11:02 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
I've always run with just short of 2qts, only about 4 ozs are left in the last bottle when lube starts coming back out the fill hole everytime i change mine. I change mine every year, for 3 years with no probs yet. Car is up on ramps at the end of my sloping driveway so the car is almost level, with the rear end slight higher. So if (1.69 qts/or 54ozs) is correct im about 6oz overfull........nothing to worry bout for me
Old Jul 27, 2012 | 11:10 PM
tom01ss's Avatar
0tom01ss
Former Vendor
when car on level ground add 2 quarts or till fluid comes out. if she want more oil add it cant do any harm.
Old Jul 28, 2012 | 01:23 AM
Dennis Wilson's Avatar
Dennis Wilson
If its over filled even a little, it will come out the breather vent on top when driving at higher speeds or in hot weather. 1.7 QT. is about right.
Old Jul 28, 2012 | 08:01 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Why change it so often? Are you racing the car?
Old Jul 28, 2012 | 08:48 AM
crAzy's Avatar
crAzy
I thought overfill with blow the seals under heavy loads? Having a breather vent rare for our kind of cars? I guess it would shoot out what's over filled right? It should I just go ahead and let some out?
Old Jul 28, 2012 | 08:53 AM
bumble-z's Avatar
bumble-z
Let some out & be done with it.
Old Jul 28, 2012 | 10:23 AM
machz800ps's Avatar
machz800ps
Did you add any anti-friction additive to it????
If not your suppose to
Steve
Old Jul 28, 2012 | 10:26 AM
crAzy's Avatar
crAzy
Steve
I have been running royal purple since I bought the car 45k miles ago. No problems, no leaks.
Old Aug 1, 2012 | 11:52 PM
84REDCROSSFIRE
cause it always comes out dirty. The clutch packs are working hard and leave lots of clutch dust in the oil.
OR I prob just have OCD
Old Aug 2, 2012 | 01:48 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
overfill will come out the breather . you might get some on your garage floor and a rag to wipe some underneath.
To Changed diff fluid today and I am concerned......
