Service ABS, Traction Control, Active handling
Old Jul 28, 2012 | 10:04 PM
Tkneapler's Avatar
Tkneapler
Default Service ABS, Traction Control, Active handling
Alright guys,
I know yall have probably heard this one a hundred times, but i have a 99 with active handling, and i am getting the dreaded "Service ABS, Traction Control and Active Handling" everytime I hit 40 MPH. From what i have found so far from my research, it is looking like it is my EBCM. Does any one know of any way i can test and make sure it is actually my EBCM, before i go and drop a few hundred dollars for a used one? Is there a good chance that its something else? Would bringing it to the dealership for what they call the "full diagnostic testing" for about $75 tell me that it IS the EBCM, or even rule that out? Thanks a ton.
Related codes are...
U1016 H - Loss of communication with PCM
U1064 H - Loss of communication with BCM
C1233 H - RF wheel speed circuit open or shorted
B2583 H - Column lock/unlock drive (B)
Terry
Old Jul 28, 2012 | 10:09 PM
chaase's Avatar
chaase
St. Jude Donor '12
Follow the standard procedure and post your codes. There are instructions you can find via search.
Old Jul 28, 2012 | 10:19 PM
Tkneapler's Avatar
Tkneapler
Whats the "standard procedure"? Im new to this forum stuff. Sorry.
Old Jul 28, 2012 | 10:53 PM
Tkneapler's Avatar
Tkneapler
Will do, Thanks.
Its a 99 Coupe, 6Spd, almost 90K miles. No mods.
I also edited the original post and added the codes.
Old Jul 28, 2012 | 11:05 PM
Tkneapler's Avatar
Tkneapler
Great. Thanks, I will do that and let you know if it helps.
Old Jul 29, 2012 | 08:53 AM
silversport's Avatar
silversport
My 2001 C5 auto trans with just 11000 miles and no mods experienced this yesterday when I started it up...mine had been on a battery tender that died (right after a big thunderstorm)...where did you get the codes???
I got the same three service codes, Active Handling, ABS and Traction Control and a check of the fuse panel under the hood looked as though all fuses were fine...
I mentioned the thunderstorm as I noticed the battery tender lights were out after the storm and it was attached to the car...
...any help would be appreciated...
Bill
Old Jul 30, 2012 | 05:04 PM
silversport
Thank you and apologies for the unintended hijack...
Bill
To Service ABS, Traction Control, Active handling
