TCS & ABS Lights On
Old Jul 30, 2012 | 11:21 PM
93Ruby's Avatar
93Ruby
Default TCS & ABS Lights On
Today my 02 6 speed threw the TCS & ABS lights with the following Codes: TCS-C1226H, A6-SCM-U1255H, & BO-RFA-C2100 HC I also recently installed a LMC5 CLB module and have a fully charged new Diehard battery. Not sure if any of these are related but wanted to post all information. I also know that the front left TPMS sensor is bad and currently reports such on the DIC. Any advice would be greatly appreciated.
Old Jul 31, 2012 | 10:49 AM
93Ruby's Avatar
93Ruby
Update to my scenario--cleared codes and drove the vehicle this morning to work and the t s & abs lights came back on and the only code I have now is C1226H.
Old Jul 31, 2012 | 03:06 PM
BigGun's Avatar
BigGun
Yep....that will do it. DTC C1226 RF Excessive Wheel Speed Variation
Check the sensor on the back of the right front hub. Its easy to get to if you remove the tire. Pull the connector apart and clean it good with electrical contact cleaner. Take a good look at the wires for any breaks or fraying. Don't let someone sell you a new hub, the sensor itself is not the problem. Search the code as there is a lot more trouble shooting you can do if it is not a simple connection problem.
To TCS & ABS Lights On
