HUD shift light
Old Aug 1, 2012 | 07:32 AM
boltnut's Avatar
boltnut
Default HUD shift light
My wife asked if the 03 had a shift light so she could feel better about what gear she needs to be in ( I agree we are both used to engines that make a lot more noise and tell you more about where they want to be) I discovered that the HUD does have a shift light but it only works in performance mode ? The manual says it lights up at 5750rpms.....I don't want to tell her thats when to shift I guess there is no way too set it for "normal" driving ?
Old Aug 1, 2012 | 09:47 AM
jsbzoh6's Avatar
jsbzoh6
Not unless there is some modification somewhere. How I taught my ex girlfriend was the goal was to keep it at 2000 RPMs. Shift accordingly on how to make that happen.
Old Aug 1, 2012 | 01:15 PM
f6john's Avatar
f6john
With the torque of these engines and the weight of the car it is almost a moot point, you can shift just about anywhere off idle and be ok. I never look at the tach while I'm shifting anyway the engine tells me what I need to know.
Old Aug 2, 2012 | 04:07 PM
oh1vette's Avatar
oh1vette
I did notice a "Shift Now" or something to that effect in 4th going 140 down ViR backstraight....
Old Aug 2, 2012 | 05:11 PM
bumble-z's Avatar
bumble-z
Install a shift light.
Lower left under the tach.
If she is starting out in third instead of first, I smell a new clutch coming your way... real soon
http://s256.photobucket.com/albums/h...t=100_0367.jpg
Old Aug 3, 2012 | 06:43 PM
zwaldo's Avatar
zwaldo
just tell her to go from first, third, to 5th. a lot less guess work then.
Old Aug 3, 2012 | 07:21 PM
bumble-z's Avatar
bumble-z
That's right.
Old Aug 3, 2012 | 08:47 PM
boltnut's Avatar
boltnut
Thanks for all the input. Actually she is probably a better manual driver than I am. I still struggle with a smooth transition in and out of first gear. I shift without looking at the tach because I feel like I am smoother without the distraction of worrying about rpm range. I think the confusion came in when the manual stated pretty conservative shift points for best fuel economy. Keeping the car around 2k feels right. Although when I really get into the peddle I wonder how much there is from 4k to 5.5k RPMS. I have never shifted over 4k or so because the car feels kinda wound out by then....maybe I'm wrong. I like the idea of adding a shift light just for grins though. Thanks again for the help
Old Aug 4, 2012 | 03:35 PM
_zebra's Avatar
_zebra
if your engine's done over 4k, you're either in 6th gear or have a dirty, sick motor. even bone stock, they'll pull to redline easily in 1-4 & should eventually make it there in 5th
Old Aug 4, 2012 | 04:48 PM
boltnut's Avatar
boltnut
I guess im just being a *****. Haven't had it long. It will take me a little while to feel comfortable going all out WOT.
Old Aug 4, 2012 | 10:19 PM
_zebra's Avatar
_zebra
just be careful & don't exceed where you feel comfortable. also note that you're gonna look down when you let off & be like " wait... i was going that fast?!" because it just don't seem like it & is pretty stable so long as the car's in good order
To HUD shift light
