I am going to be doing the clutch in my car soon.
What slave cylinder should I get? I know I want GM. Is another year better than another?
Car is a 2001 Z06
Clutch is McLeod RXT.
What makes that bleeder worth 3X's as much as the Tick bleeder?
I wouldnt mind knowing the answer to that one myself. I too have a Tick bleeder works as advertised. As to the response with to the post about a GM slave. Maybe you should do some research bc the stock slave does fine in most street applications. Just replace it when you change the clutch to spare yourself the ***pain of going back in there to fix somthin you shoulda done the first time. Ive had my Monster Stage 3 with LW flywheel for almost 2 years now. STOCK SLAVE no issues.
I don't think you have any options other than stock for slave cylinders. However, you can use a Centerforce TO bearing on the stock slave, which is supposed to be superior.
