I've had a random ABS and traction control warnings and lights pop up on a drive the other day. It was a hot dry south TX day I pulled over and turned the car off and restarted it and all is well.
However, I have noticed that the car seems to be starting slower like the battery is about to go. Would that be the most likely cause of the freak out?
I know it's not a lot of info but this is the first time it's ever happened. There were no vibrations, sounds, or smells associated with the light show. Car is a 2004 and has 16,000 miles.
Yes, the battery could cause random faults (alarms) so before I started cleaning grounds and checking connections, I would make sure I had a fresh battery, fully charged. I did and all was well for almost 10k miles before the EBCM failed, permanently. ABSfixer and all is well once again.
I'll check the coeds when I get home but it's on it's second battery that is 5 years old at least and it does alot of setting around too.
The battery connections are clean.
Make sure you get one that is rated for the car. Optima does not make a battery that has enough reserve capacity. Get the Odyssey or Sears DieHard Platinum (made by Odyssey).
I bought mine with a Red Top already installed and it had electrical gremlins until I put a proper battery in it and has not hiccupped in almost a year.
C1226 LF Excessive Wheel Speed Variation
C1276 Delivered Torque Signal CKT Malfunction
B2282 Battery #1 Fault
B2286 +5V Reference Fault
B2284 Battery #2 Fault
U1064 Loss of Communication with BCM
U1016 Loss of Communication with PCM
B2283 Battery #1 Fault
B2287 +5V Reference Fault
B2285 Battery #2 Fault
This is the first time that I've ever looked at that codes so I have no idea if any were set before this incident or not. All codes are histroy codes and non are currently active. I drove the car to work on Friday with no issues but I haven't had a chence to go to the parts store to look at battries.
