Throttle body coolant bypass?
Old Aug 4, 2012 | 09:32 AM
flyinlow427vette's Avatar
flyinlow427vette
Default Throttle body coolant bypass?
I just saw this mod and while it makes sense to route the coolant away from the throttle body, does it really make a difference? Doesn't the coolant going through the throttle body serve a purpose?
Thanks for your insight!
Old Aug 4, 2012 | 09:52 AM
bumble-z's Avatar
bumble-z
I wouldn't bother.
Old Aug 4, 2012 | 10:14 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by bumble-z
I wouldn't bother.
Old Aug 4, 2012 | 10:58 AM
baxsom's Avatar
baxsom
if you live in a cold climate it supposedly helps warm up the air going into the intake or something like that. i bypassed mine just because then i wouldnt have to mess with the coolant every time i took the throttle body off
Old Aug 4, 2012 | 02:21 PM
Marine One's Avatar
Marine One
I did it for the same reason. I also got the part at Lowe's for less than three bucks.
Old Aug 4, 2012 | 02:28 PM
AFTRBRNR's Avatar
AFTRBRNR
Same, it took me all of 2 minutes to put on so why not. Trust me, there is no noticeable gain from doing this.
Old Aug 4, 2012 | 03:18 PM
_zebra's Avatar
_zebra
it was designed to keep the TB from freezing in cold climates & from what i understand, the air moves through its relatively small area fast enough that there's virtually no heat soak coming from it. that said, it's more of a convenience thing if you take your TB on & off.
Old Aug 4, 2012 | 04:58 PM
NukeC5's Avatar
NukeC5
I did it for the same reason. To not have to mess with coolant every time the throttle needs removed. Plus, I had the parts just sitting around. I did this on my old LT1 Trans am too. It does make the difference in that you can hold your hand on the TB no matter how long you just drove it. Before, it was way too hot. Yes, the air travels through so fast it probably doesn't make a difference, but it is also not heating up the intake any more by being connected to it. I say why not do it? I just helped my friend port and polish his TB on a 06 Ram. It did not even have a coolant line running to it. There's really no need. If anything, you will save the life of the sensors at the throttle. They get to enjoy a much cooler life.
Old Aug 4, 2012 | 07:17 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I had to put the bypass in there. The C6's don't have the coolant going into the throttle body.
I installed a C6 LS2 TB, with my Fast 92 intake.
Old Aug 4, 2012 | 09:24 PM
flyinlow427vette
Great to know, thanks for all the info. Sounds like it is not as important as a catch can.
Old Aug 4, 2012 | 10:16 PM
_zebra's Avatar
_zebra
same here for my TVS
To Throttle body coolant bypass?
