coolant tank leak fix?
Old Aug 5, 2012 | 03:08 PM
dmarkshark's Avatar
dmarkshark
Default coolant tank leak fix?
I have a small pin size hole leak on my coolant tank. Is this fixable, any suggestions appreciated. Thanks
Old Aug 5, 2012 | 03:17 PM
havocdog's Avatar
havocdog
Don't know if it's available in your area but I've repaired several tanks using Rapid Fix, a two part product thats like CrazyGlue, JB Weld on steriods.
Old Aug 5, 2012 | 04:01 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Whatever you decide to use needs to be capable of withstanding coolant temperatures up to 250 degrees, and pressures of up to 18 PSI.
I would just replace it instead.
Old Aug 5, 2012 | 04:24 PM
lucky131969's Avatar
lucky131969
Considering where you live, and how much burdern is on the cooling system, I would not attempt a repair. ~$50 for a new tank.....~$100 for a tow.....your choice.
Old Aug 5, 2012 | 04:42 PM
dmarkshark's Avatar
dmarkshark
Thanks guys, thats what I thought, just ordered a new one.
Old Aug 5, 2012 | 04:49 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
A new tank isn't that expensive. Not worth the risk of failure and being stranded or worse over-heat the engine.
To coolant tank leak fix?
