Ls1 t ls6 intake swap
Old Aug 6, 2012 | 06:18 PM
FRITZM's Avatar
FRITZM
Default Ls1 t ls6 intake swap
What parts, if any, can be transferred from my ls1 intake to the ls6 intake? What other parts in addition thereto do i need to complete the swap. Suggestions/comments please. Old but still a new here.
Old Aug 6, 2012 | 08:08 PM
thepitstop2010's Avatar
thepitstop2010
Everything from the ls1 intake will transfer to the ls6 intake but you will have to buy the ls6 style coolant pipe and the 2 rear coolant plugs.
Old Aug 6, 2012 | 08:09 PM
baxsom's Avatar
baxsom
or you leave the cooling system alone and shave off the ribs from under the intake where they contact the tubes. if you are going to modify the cooling system to do the swap you should get two crossovers and then T them together so your back banks done run hot. It has been talked about on here a few times how the #7 piston can run hotter with the back vents plugged.
Old Aug 6, 2012 | 10:03 PM
FRITZM's Avatar
FRITZM
Default Intake swap
Thanx for the input. I won't alter anything for expedience sake and will go the cooler lines route. Just makes more sense than modifying the ls6 intake. Do you know if those lines come in a kit and if so where to buy?
Old Aug 6, 2012 | 10:07 PM
thepitstop2010
I'm sure some gmpartshouse can help you out. They are a vendor here.
Old Aug 6, 2012 | 10:38 PM
FRITZM's Avatar
FRITZM
u r right. if anybody knows gene will.
To Ls1 t ls6 intake swap
