Master Engine Tuner Magazine update
Old Aug 7, 2012 | 01:05 PM
MasportDan's Avatar
0MasportDan
Former Vendor
Default Master Engine Tuner Magazine update
For the tech-junkies out there, we've posted new articles recently including the following:
COMPUTER-CONTROLLED IGNITION SYSTEMS
If you could use a better understanding of computer-controlled ignition systems, check this out:
http://masterenginetuner.com/
Coming soon:
Fuels - Pump Gas vs. Race Gas vs. E85
(you'll be surprised when you see what made the most power!)
Tuning for E85 - We show you how to convert your car to run on E85 using a 2010 Corvette Grand Sport as an example. It takes less than 1 hour!
Tuning for new Fuel Injectors - Do you know what Break-point, High-Slope, Low-Slope, Offset and non-linear range mean? If not, this article will help you understand the modern fuel injector and help you tune your engine perfectly when you install a bigger injector.
Part Test - Tomorrow we're testing Accel's new Firestorm Ignition System for LS engines on the dyno. We'll see what PeeWee can throw down with this new ignition system.
The updates will keep coming, so check back often and "LIKE" Master Engine Tuner on Facebook to be the first to hear about the updates!
Cheers!
