End Links? Did I make a Mistake?
Old Aug 7, 2012 | 04:30 PM
JJBZ06's Avatar
JJBZ06
Default End Links? Did I make a Mistake?
I have a 03 Z06.. I saw GMParthouse special for new C6Z06 suspension package, shocks, sways etc.... and all the raves about the upgrade.. So I bought it.. been on the car about 2-3 Months...
However what I didn’t read is the Sways were meant to upgrade C5 Base models .. .not intended for C5z06..oops on my part..
but since I had them, I installed them anyways...
2-3 months later,, I have front end links failing (Loud clunking noises, low speed, bumps..).. Is this a coincidence? or is there a fitting problem? Should I go back to my stocks?..
Old Aug 7, 2012 | 05:02 PM
lucky131969's Avatar
lucky131969
You are absolutely certain, that an end link(s) has failed? In what way?
Old Aug 7, 2012 | 06:46 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
The C6Z bars are larger than the base C5 and C5Z bars, and while the contrast is more noticable compared to the base bars there is no fitment issue with using them on your Z. I am assuming you reused the end links on your Z with the new bars and they could simply need to be retightened to the specs.
Old Aug 7, 2012 | 06:58 PM
k24556's Avatar
k24556
did you lube the rubber bushings? the sway bar will pop in the rubber bushing if it is dry. Put a little di-electric grease in the bushing and make sure they both slide easily on the sway bar and the noise will probably go away. The links have a spherical seat in them and I would doubt you broke them. The original base links, non Z06 were plastic, so they really do not see a big load.
You are just a few miles from me I'm in Goode.
Old Aug 7, 2012 | 11:17 PM
JJBZ06's Avatar
JJBZ06
I will try lubing the bushings.. The ones that came from GMpartshouse for the rear fit perfect, the front ones were a little tight and i have to really crank on it to sit flush.. so could be too tight, but i am just now hearing things.. 2-3 months later..
Well I Jacked up the car, pulled the wheel, and I was essentially able to move the end link with my hand, it seemed to have soooo much play in it. Bolts "seemed" tight, but I will torque stick them again...
Old Aug 8, 2012 | 04:39 PM
CHJ In Virginia's Avatar
CHJ In Virginia
If you had to crank down on the front bushing clamp, it is too tight for proper sway bar movement. When the clamp is tightened the bar should be able to be easily rotated in the bushing with your hand. If too tight, it will load up and Pop as it moves making a bad noise. Remove clamps, lube bushing with high temp silicone grease, then test movement with end links disconnected. If still very tight, put a single washer under one end of the clamp and tighten down - try to move - if still too tight add another washer, etc. That should fix your problem.
Old Aug 8, 2012 | 05:32 PM
RonSSNova's Avatar
RonSSNova
I posted this up a while ago how the bushings were actually wrong for the application. They fit the bar fine, but not the bracket. I built spacers for mine from .150" thick aluminum. I also added Zirk fittings to the brackets for greasing.
At the same time I added the C6 bars, I replace the end links. The holes in the bar where they bolt on are sloppy to the end link bolts. So much so that if they get loose at all they are going to clunk. Forget the torque spec, tighten them until the clunk goes away. I was tempted to machine some sleves for the bolts where they pass through the bar to take up the clearance. I may still do that because it bugs me.....
Ron
Old Aug 8, 2012 | 09:10 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Ron
Ron,
like the pics...way more helpful than the common rhetoric I've been getting. So, your hand is showing the 2 gaps that you fixed with the aluminum spacers, right? looks like a huge gap.
Old Aug 9, 2012 | 12:51 AM
RonSSNova's Avatar
RonSSNova
Yes, maybe my spacers were .25".
At any rate, the bar is just snug in the bushing. As was mentioned above, you don't want it bound up.
I'm not sure why the bars come with the wrong bushings......
Old Aug 9, 2012 | 09:10 AM
JJBZ06's Avatar
JJBZ06
This is really helpful information, I should have thought to use some spacers to assist in not having it so tight. More i think about it, the more i realize how tight they really were. Tonight I am going to pull the front and back sways, and redo the application with the proper spacing and lube. I did in the meantime order new end links anways.. to be safe, so.. got plenty to do tonight.. Very Very Helpful!!
Old Aug 9, 2012 | 09:21 AM
RonSSNova's Avatar
RonSSNova
Glad it helped. Let us know how it comes out!
Ron
Old Aug 9, 2012 | 02:19 PM
$$$frumnuttin'
and those end links will go on very easily and fast.
To End Links? Did I make a Mistake?
