Leveling exhaust tips.
Old Aug 7, 2012 | 04:31 PM
boltnut's Avatar
boltnut
Default Leveling exhaust tips.
One set of tips is a little lower than the other. Am I correct that the best way to even them out is to slight bend the hanger tabs that are welded on the muffs ? Shim the mount ?
Old Aug 7, 2012 | 04:59 PM
bumble-z's Avatar
bumble-z
On the side you want to adjust. (Up or Down)
Loosen the two bolts/nuts at the flange conection between the catback pipe and the H or X pipe. (which ever system, you may have)
Have a second person hold the chrome tip at it's proper position &
re torque the loose hardware.
Your now good to go.
Old Aug 7, 2012 | 05:01 PM
boltnut's Avatar
boltnut
Ah....so easy. Now to get under the car !
Old Aug 7, 2012 | 05:35 PM
hornet7's Avatar
hornet7
Default tips
IF YOU DO NOT HAVE YOUR HELPER, USE A HYDRAULIC JACK AND A BLOCK OF WOOD. LEVEL THE TIPS AND TORQUE THE CAT BACK FLANGE.
To Leveling exhaust tips.
