make shure the wiring pins look the same there is one missing on the vettes. 3rd one from left with an R above the missing one. i ordered a used one one time and it looked the same and i plug it up and tried it and started to smell smoke . after looking over it with mine it had all 6 pins and the vettes have 5 . just some info.
I took mine apart and removed the plastic gear. I then used a stainless steel washer that I drilled out to match the gears OD and ID and JBWelded it to the assembled broken gear pieces. PERFECT REPAIR! It will last a LONG TIME!
BUT I'm a cheap b*&^8d and it's way easier to buy the whole thing.
They go on sale for around $90 occasionally. I see they're now more, I was going to say they had a cheaper one but it's the same one. Just marked way up so they can rape you.
