If your just wanting to run the fans between runs at the drag strip.
Here is a way to do it. FREE
Just keep the wire/pigtail in your console or glove box, when not needed.
i did the relay jumper method, but i ran the wires (some thick-insulated speaker wire) around the back of the engine and into the cabin with my boost gauge reference then under the dash to my center console. the switch is on the front wall under the armrest just next to the power port. works like a champ
At the PCM in the lower left you will see that all the PCM does to start the fans is ground C1-42 and C2-33. You will see at the top of the diagram that power to the associated fuses and relays for the fans are "HOT at ALL TIMES"
If you provide ground on both the DK GRN and DK BLU wires out of the PCM the fans should start in high mode.
Ground to only DK GRN starts both fans in low speed mode.
Ground to only DK BLU starts the the right fan in high speed mode but the left fan will not run. (requires ground of DK GRN to run)
That's not how the fans work. GM achieved low speed fan operation by connecting them in series so that approximately 1/2 of 12 volts is dropped across each fan. That causes the fans to run slower than they were designed. In high speed mode they put the fans in parallel electrical connection so that each fan has 12 volts across it and each fan then runs at rated speed. If you have 12 volts across a factory fan it is NOT running at low speed but rather it is running at high speed.
If yours work differently then you either have some wiring other than factory or you have a problem... ie fan out, fuse out, relay failure or some wiring problem such as a short.
I have a spare set of fans, battery voltage to each individually makes one run at high speed and the other at low, so I assumed that the fan motors were not identical.
Kind of hard to evaluate proper operation, having taken the assembly out of the circuit. Consult the schematic above. The relays dictate whether the fans are in series....or parallel.
so this "If you provide ground on both the DK GRN and DK BLU wires out of the PCM the fans should start in high mode" should do it ???
If you ground both those wires the fans WILL start in high speed mode EVEN WITH THE KEY IN THE OFF POSITION. As I stated the power to the fuses and relays for the fans is ALWAYS hot.
So when you "push" your button to cause the ground without the engine running, you had better remember to "unpush" your button or you will kill the battery in short order.
i just finished this
took DRK blue 33 on green connector and DRK Grn 42 on the blue connector to ground (this is a 2004 PCM)
but i only get one fan running !!!! the passenger side fan it runs in high mode the other is just stop but i hear both relays click but only one running
and i need to have the switch power on, it don´t run otherwise
not necessarily. i've ran mine for 4-5 hours at a time with no adverse effects. that said... i sure wouldn't try running them all night or anything
Where is the best place to tap into these wires?
