Upper control arm bolt wont completely tighten
Old Aug 12, 2012 | 08:39 PM
9krpm's Avatar
9krpm
Default Upper control arm bolt wont completely tighten
As the title states yesturday I was lowering the car and I was on the last bolt and I must have over torqued it and now the bolt wont tighten all the way. All though it is flush and still treads and rethreads it wont tighten to 46lbs. Has anyone had this happen? what can I do to fix it?
thanks,
bryan
Old Aug 12, 2012 | 09:34 PM
bumble-z's Avatar
bumble-z
You talking about one of these four bolts?
http://s256.photobucket.com/albums/h...t=100_0351.jpg
Old Aug 12, 2012 | 09:36 PM
9krpm's Avatar
9krpm
yes sir those are the four bolts the one on the very right wont tighten all the way but it is flush
Old Aug 12, 2012 | 09:49 PM
bumble-z's Avatar
bumble-z
What do you mean, "wont tighten all the way"??
Did you put the spacers/washers back into their proper locations?
Old Aug 12, 2012 | 09:54 PM
9krpm's Avatar
9krpm
yes All the washers are back in the correct location but the one on the very end is completly flush but wont tighten to 48 lbs? They each only had one washer and I put all of them in the same location. Is there a locking nut behind the hole or is it just a threaded hole in the reinforcement?
Old Aug 12, 2012 | 09:59 PM
bumble-z's Avatar
bumble-z
If it doesn't tighten to 48 lb ft, then what the heck is doing??
Spinning?, when you apply 5 or so more lbs of more torque, it doesn't turn/move?
Old Aug 12, 2012 | 10:00 PM
9krpm's Avatar
9krpm
It will tighten then let lose then will tighten again
Old Aug 12, 2012 | 10:04 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Have you looked at the threads? Stripped more than likely
Old Aug 12, 2012 | 10:06 PM
bumble-z's Avatar
bumble-z
You need to pull all four bolts back out.
Swing the arm out of the way & see if that one bolt will go all the way in
till it is tight up against the threaded female mount.
If it does so, with no problem.
start all four of your bolts through the a arm & tighten them back down, alternating .... going from one bolt to the next, bringing the a arm evenly back into position, until tight.
Sounds as though you may have had that one bolt in a bind.
Old Aug 12, 2012 | 10:18 PM
9krpm's Avatar
9krpm
I just went and took the bolt out and put a differnt bolt in the hole and it tightened all the way. Now it seems to be fine. What a weird thing to go wrong!
To Upper control arm bolt wont completely tighten
