Techron question
Old Aug 14, 2012 | 12:00 PM
smithd7's Avatar
smithd7
Default Techron question
Is there any difference between the Techron fuel system cleaner and the pro-gard fuel injector cleaner ? Both bottles read the same as for contents.
Old Aug 14, 2012 | 12:12 PM
Pumba's Avatar
Pumba
Yes, the Techron Fuel System Cleaner will keep your fuel sender unit from becoming coated with sulfur, in addition to cleaning the rest of your fuel system and injectors.
Old Aug 14, 2012 | 05:42 PM
joe Villarreal's Avatar
joe Villarreal
:iagree drop 1 bottle in every 3 months
Old Aug 14, 2012 | 06:20 PM
anykeys's Avatar
anykeys
Serious question, not being a wiseacre, but how do you know it works?
There are so many brands on the shelf with outrageous claims that I ignore pretty much all of it. I'd love to be able to believe in some of them but have no idea which are legit.
Old Aug 14, 2012 | 06:36 PM
bighank's Avatar
bighank
Default Have had the guage go to zero a dozen times TECHRON WORKS
If it did not resolve the zero gas guage reading I wouldn't use it.
Seafoam also works. The sending units in the C5 are CRAP. No other car GM, Ford or MOPAR I have ever owned had the sulpher sending unit problem. First time it happened the dealer replaced the sending unit in one tank. A year later it happened again. Techron will work and give the sender another chance. Used Texaco for years which has Techron in it. Still had the guage problem occasionally. Look here in the forum,
there are scores of not hundreds of posts on this problem.
Old Aug 14, 2012 | 06:48 PM
anykeys's Avatar
anykeys
Will Seafoam do the same job that the Techron fuel sys cleaner does?
Old Aug 14, 2012 | 07:01 PM
NukeC5's Avatar
NukeC5
So fueling up with Chevron w/ Techron is not enough? I should add a bottle to a full tank every so often?
Old Aug 14, 2012 | 07:03 PM
joe Villarreal
yes chevron gas with techron is good but a bottle or so is good by itself.
Old Aug 14, 2012 | 07:09 PM
NukeC5's Avatar
NukeC5
It wont be too much additive to put a bottle in with chevron fuel? Ive seen spark plugs turn bizarre colors from too much additives etc. I do want to run a fuel system additive because I haven't since I bought the car 5 months ago.
Old Aug 14, 2012 | 09:33 PM
bighank's Avatar
bighank
Default I only add Techron or Seafoam when the guage goes to zero
I do not routinely add either Techron or Seafoam every 3 months or so.
When (not IF) the guage goes to zero I add a 20 oz bottle or a single can of Seafoam to the tank half full and then fill it up. If this does not cure the zero reading in a day or so (needs some time to work) I add another bottle of whichever I used. I do not mix them.
This will "cure" the guage problem for several months.
Watch it with el cheapo gas. Found out the hard way that even 93 octane from Sams Club will kill my guage.
When you use it add to partial tank then fill to the top. This insures it goes into both tanks and gets both sending units. Either one will cause the guage to go to zero.
Old Aug 14, 2012 | 10:29 PM
C5FORFUN2's Avatar
C5FORFUN2
There are actually a lot of others that have the same problem. I know personally that Silverado's do and have seen it with others. Using generic gas with low or no additives seems to be the cause. I only use Chevron and have never had a problem with my 01 coupe going on 119K now, but the wife drove the Silverado and got gas where ever it was convenient, usually Safeway or Fred Meyer. Have started using Chevron in it and added Techron once so far, it's working better already.
Old Aug 14, 2012 | 10:55 PM
onspeed's Avatar
onspeed
Nobody answered the OP's question...
Yes there's probably a difference. The contents probably lists "proprietary ingredient" which the secret recipe for that product. But I've used the pro-grad product from walmart before and it fixed my gauge just the same.
Old Aug 15, 2012 | 02:28 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Techron will also help the gas tank electrical problems.
Old Aug 15, 2012 | 06:02 AM
Cybermind's Avatar
Cybermind
It's my understanding that the Techron additive is unique as far as the ingredients are concerned and it is the only additive proven to work on this forum. Unfortunately for me, it is not available in Canada so I need to go across the border every once in a while to pick up a few bottles. I've never had the fuel sender problem but I just add a bottle once a year as a preventative measure.
Old Aug 15, 2012 | 07:01 AM
04blackice's Avatar
04blackice
My? Now..does 91 have more tech than 87
Old Aug 15, 2012 | 07:08 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I realize that this doesn't address the OP's question either, but I've been using Red Line's fuel system cleaner in my '01 on a regular basis, and I've never had any fuel gauge issues.......(knock on wood!)
Old Aug 15, 2012 | 07:42 AM
runner140*'s Avatar
runner140*
Ah....the secret sauce.
To Techron question
Old Aug 15, 2012 | 10:16 AM
99 vett babycar's Avatar
99 vett babycar
Originally Posted by anykeys
Serious question, not being a wiseacre, but how do you know it works? .
We've used it and the fuel gauge problem goes away.Most of us guess that the result might have sdomething to do with pouring the Techron into the tank.Then ,again, maybe not.There's no scientific proof, just a guess.
Old Aug 15, 2012 | 10:19 AM
99 vett babycar
I've used both. they both seem to work fine. most often I use the techron because of price considerations.You can usually get a better price on the Techron when the auto stores run their 2 for 1 sales.
Old Aug 15, 2012 | 11:43 AM
smithd7's Avatar
smithd7
Thanks onspeed,
That's kinda what I thought. I bought a six pac of pro-gard from Costco and thought
maybe it might be the same. I've had my '99 since new and have never had any fuel sender problems yet ! Do you think that the sulfur content of fuel in different regions of the country might be a factor in how often the problem happens ? Just a thought.
Also I see where you can order a six pac of the Techron fuel system cleaner (20 oz.)
from Walmart for around $60,sure beats $13 a bottle from parts houses.
