After searching for mod red pieces for a while, i have came to the conclusion i will dye my currently black pieces (door panels, knee bolster, and glove box) to match the mod red OEM interior on the Z06's. I know i am going with the SEM Dye and was also wondering if anybody knew the color coding for the mod red? What kind of prep/supplies are needed and what are basic instructions/tips on doing the task. If someone could point me towards a write up or make one up i would gladly appreciate it. I'm trying to get this done right the first time.
Presuming you have proper paint gun and experience to use it.
1-obtain materials from auto paint store. a-pint of torch red color SEM code 4793. b-base coat white in spray can SEM 15103. c-low gloss clear SEM 1302. d-wax/grease remover. e-tack rag
2-clean parts using wax/grease remover
3-mask off areas to receive color, tack wipe
4-spray white base, one coat at time till fully covered [2-3], allow flash dry between coats
5-spray color coat until coverage obtained, color will likely appear too cherry red and have excessive gloss level.
6-spray low gloss clear 1-2 coats, this will change the color from cherry red to orange red and reduce gloss level.
thanks a lot! exactly what im looking for... Few questions: the torch red color will be the dye correct along with the white base? if i dont have a paint gun will a preval-sprayer work fine? Also Step #6 will come right after Step #5 so do not let the color paint dry? Immediately spray the low gloss clear?
Reason: added information
I may be doing the same job soon. I've always wanted mod red interior. I kick myself now for not buying the 03 Z06 I was originally looking at. Oh well, that dude wouldn't budge. Got a better deal on a lower mileage '02
I hear you bud i was in the same scenario... But hopefully i can get this job done right and replicate the oem mod red interior
Where can I find the torch red in cans? The only color I can find close i the cans are Flame Red I wonder how close that would be. Also how many cans of each do I need for the panels/bolsters? Thanks!
I tried the "dyes" and they are a lot of things but "dye" isn't one of them. Low viscosity, low pigment density PAINT, yes, dye - no. On the longest day you live don't use the "dye" on any surface that you will touch in any manner. The "dye" will crack, wear off, and look like crap in a matter of months. And for those that want to debate surface prep and how the project would have turned out differently had I properly prepped the surfaces - no it wouldn't. The "dye" dries to a hard, relatively inflexible paint surface and it cracks and wears easily and quickly.
Well id be willing to give a try at my own discretion. A few other people have done this task and have been happy since. Sincerely no offense to you at all. Ill be doing this in the next few weeks. This weekend i'm swapping out my black z06 seats for the mod red seats. Will keep you guys posted.
