Stall converter questions
Old Aug 14, 2012 | 11:10 PM
CactusCat's Avatar
CactusCat
Default Stall converter questions
Going to be adding a stall torque converter to my 98 A4 soon. I've never driven or rode in a car with a stall converter. I have a couple of questions that I'd like some respones to. Since the converter "slips" at lower rpms, during normal (not racing) driving, does this tend to get your transmission fluid hotter than normal? This brings me to question #2, which is, does the A4 cars have a transmission cooler built in and if so, does it provide adequate cooling or should an aftermarket cooler be used? My last question is, if a 3400 stall coverter "slips" until it hits 3400 rpm, is that the rpms where the unit "locks"? And if so, if I'm driving at 2K rpm at 70mph on the highway, is the 3400 converter slipping a little? Thanks guys.
Old Aug 15, 2012 | 02:13 AM
NukeC5's Avatar
NukeC5
No there is not a cooler, and yes, you must use one with a stall converter. Locking is different depending on the type of converter you go with.
Old Aug 15, 2012 | 08:38 AM
thepitstop2010's Avatar
thepitstop2010
Yes, make sure that you use a aftermarket cooler and only run through that cooler not the one in the radiator and your aux. cooler
Old Aug 15, 2012 | 10:03 AM
99 vett babycar's Avatar
99 vett babycar
the speed at which the TC locks up in each gear is determined by your tune, not by the stall of the TC.
If you do not fool with your tune your TC will continue to lock up at the same speed its locking up now. So at 70mph and 2k rpm you'll be locked.
Get a trani cooler.
The car will feel "loose" off the line but you'll get used to it in a few weeks.
Anyone who drives your car will be suprised that it dosen't "jump" off the line like they ex[pect a Vett to do.
If you want it to "jump", hold the breakes, rev to 2200 and let go as you punch it.It'll jump.
Old Aug 15, 2012 | 10:14 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Wrong!!!
Your tranny cooler is up with your auto radiator( kind of all
together in one frame). Depending on the stall number the
lower you would not need a separate cooler. But tranny
coolers can be a wise thing to do. There is alot of ways of
installing a sparate cooler. MIne runs from the cooler up
front back to a B&M tranny cooler. Some bypass the front
cooler. This will be up to you.
Now I have forgot your other questions.....................
Old Aug 15, 2012 | 10:25 AM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
As already stated, yes, a higher stall speed converter will raise the fluid temps in your trans. But your car does have a build in trans cooler. It isn't very effective but it is adequate for a stock setup. I would recommend an external cooler. A 3400 converter doesn't technically "slip" to 3400. When driving the car around normally you may only see 500-600rpm of added stall speed under light throttle. Most high quality replacement stall converters have an integreated "lock up" clutch in them just like the factory torque converter. This lockup clutch engauges when you are at a specific cruising speed with low throttle input. All converters lock at the same time because the lock up point is set in the ECM tuning. This clutch basically locks the engine and transmission together and eliminates all internal converter slip. So by doing this you will see zero difference in your car on the highway with the converter locked up.
Hope this helps. Let me know if you have any more questions.
Old Aug 15, 2012 | 10:29 AM
NukeC5's Avatar
NukeC5
Originally Posted by road pilot
Wrong!!!
Wrong? Go ahead and use the radiator tank for a stall converter set up and see how long the transmission lasts. Everyone knows that the fluid is routed to the radiator. Its obvious that he was asking if there was an external cooler. Even a stock set up can benefit from a cooler. And those that do not bypass the radiator are foolish because they re-heat the fluid as it passes through
Old Aug 15, 2012 | 01:31 PM
road pilot's Avatar
road pilot
I told you there were going to be all kinds of opinon to the
question---( that's for CatusCat )
I replied from the question asked "does the A4 cars have a transmission cooler built-in"
Answer--Yes.
Old Aug 15, 2012 | 04:13 PM
CactusCat's Avatar
CactusCat
Thanks all! This is exactly the info I was looking for. I'll start looking out for the aftermarket cooler now to go with the converter. Thanks to all for helping out. You guys are the best !!!
Old Aug 16, 2012 | 09:46 AM
Mike Mercury's Avatar
Mike Mercury
http://forums.corvetteforum.com/c5-t...-da-floor.html
To Stall converter questions
