need to know ?
Old Aug 15, 2012 | 01:08 PM
G.C.'s Avatar
G.C.
8th Gear
Default need to know ?
installing g-force power chip in my 02 z06 405hp there are 5 differnt color wires connected to the mass air flow sen. does anyone know what color the 2 wires you have to use to hook up the unit thanks G.C.
Old Aug 15, 2012 | 01:28 PM
lucky131969's Avatar
lucky131969
Originally Posted by G.C.
installing power chip in my 02 z06 405hp there are 5 wires to the maf do anyone know what color the 2 wires you have to use thanks G.C.
Ok...you got me. What is a "power chip", and how/why does it connect to the MAF??
Old Aug 15, 2012 | 01:29 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Old Aug 15, 2012 | 01:32 PM
G.C.'s Avatar
G.C.
8th Gear
Originally Posted by lucky131969
ok...you got me. What is a "power chip", and how/why does it connect to the maf??
g-force chip increases hp power hooks to mass air flow sen. Tks
Old Aug 15, 2012 | 01:38 PM
lucky131969
I see. Sounds exciting. Good luck with that.
Old Aug 15, 2012 | 01:44 PM
tlove32's Avatar
tlove32
In other words.....STAY FAR AWAY FROM THAT CHIP THINGY!!!
Old Aug 15, 2012 | 01:47 PM
RealmSteel's Avatar
RealmSteel
Have you done any research on this?
Do a Google and you will find a video of installation.
I'm curious if this is different than any of the other total scam pieces out there.
I recently bought a '01 300M Special from my neighbor.
He talked about having a performance chip in it.
The car needed some things fixed and one of them was the AIT sensor as it kept throwing a code for it. Low and behold that is where the "chip" was installed.
I removed it and proceeded to take it apart to verify....yes, all it contained was a $.05 resistor. Oh it did also contain a piece of cardboard and a huge glob of heat glue where the resistor was hidden inside.
I hope your device is something legitimate, but I would have to bet against it.
Old Aug 15, 2012 | 09:48 PM
LawdoG247's Avatar
LawdoG247
Do not hack up your harness for this scam, get a refund if you can. Cleaning the MAF, SeaFoam-ing the combustion chamber, installing a drop in K&N filter, implementing the zip tie mod (or the flip tie mod if you're feeling frisky), and an idle relearn will net you far more gains than this crap.
Don't disrespect the heritage of that Z with "snake oil" products, throw those in the bin with *****-enlarging pills and hair re-growth products!
Old Aug 15, 2012 | 09:51 PM
NukeC5's Avatar
NukeC5
Yes, there have been many threads on many forums about this scam. It is not real and will do nothing for your performance. Send it back. Dont get took by the jerks.
Old Aug 15, 2012 | 11:40 PM
PUMP03's Avatar
PUMP03
Oldtimer
The attached pic shows the MAF Sensor connector and associated wires by color/function. If you can't figure out from the pic how to get where you want to go, then you better stay away from this mod.
Old Aug 16, 2012 | 01:32 PM
LawdoG247's Avatar
LawdoG247
Have you researched HOW it increases HP? The only thing it could possibly do to increase power by the slightest bit is trick the computer into running a leaner air/fuel ratio based on the altered readings it's getting from the MAF. Too lean a mixture and BANG, there goes your engine! It's your car, do with it as you wish!
Old Aug 16, 2012 | 02:52 PM
KillSwitchNY's Avatar
KillSwitchNY
DO NOT INSTALL A PERFORMANCE "CHIP"!! I would also stay away from the handheld tuners as well. You want results and piece of mind, have a reputable tuner put the car on a dyno and tune it after you have done some airflow mods I.E. Intake/exhaust...
"chips" are a gimmick and dangerous to your computer system and engine.
Old Aug 16, 2012 | 03:24 PM
chaase's Avatar
chaase
St. Jude Donor '12
Old Aug 16, 2012 | 05:16 PM
MStrahan's Avatar
MStrahan
I really want to believe this isn't a serious question, but someone considering hacking up their wire harness I have to believe is serious.
To the OP: DON'T INSTALL THAT JUNK!!!! Seriously listen to the guys posting on this thread and run away from that snake oil. You've got a great car as it is in stock form. If you can't afford to mod it properly, then don't try cheap tricks. There's nothing wrong if you can't afford quality mods as you've already got a Vette. You are going to end up costing yourself a bunch of money down the road in repairs when this thing goes **** up. Save your money and avoid having folks make fun of you behind your back.
Old Aug 16, 2012 | 05:29 PM
zeevette's Avatar
zeevette
I say, DO IT! Please report back with startling results. Pictures of installation would be nice, too.
Old Aug 16, 2012 | 07:31 PM
lionelhutz's Avatar
lionelhutz
Any properly build scam item should have the correct connecors for a plug and play install. What a half assed attempt at ripping people off this thing must be.
Old Aug 16, 2012 | 08:11 PM
Casket86's Avatar
Casket86
Not to hijack the thread, but what the heck is the zip tie mod. Been searching out of curiosity, but have not found it yet.
To need to know ?
Old Aug 16, 2012 | 08:25 PM
lucky131969
What do you mean, "not to hijack the thread"? That exactly what you did, with a subject matter that is completely unrelated. ....but, it's a lame thread anyway.
Google rocks.....
http://ls1tech.com/forums/corvette-p...p-tie-mod.html
Old Aug 16, 2012 | 08:44 PM
Darion's Avatar
Darion
Google rocks.....
Hey at least the Zip Tie mod was mentioned above hence his question.
It is a lame thread though!
Darion
Old Aug 16, 2012 | 09:03 PM
Casket86's Avatar
Casket86
Thanks for the info. I would never hijack a thread that was actually important.
