***Fog Lamp Question***
Old Aug 15, 2012 | 03:43 PM
PY310L's Avatar
PY310L
Default ***Fog Lamp Question***
Just had both lamps stop working. Checked all the fuses and relays. Everything checked ok. Tried 2 new bulbs nothing. Then took a tester to the passenger side harness, which showed the harness was getting power on one side and no ground on the other. The drivers side harness was getting power on both sides??? Coincidently, while the vette was on the lift, I noticed that one of the rear LED HALO lights was out. The harness was water damaged and looks like I need to get a new tail lamp but would the Halo Light have any effect on the FOG Lamps? Has anyone experienced anything similar?
I also installed the Hyper flash harness couple years back when I put in the halos. Any help would be apprecieated
Old Aug 15, 2012 | 06:47 PM
PY310L's Avatar
PY310L
Was a bad ground. I got it working. Thanks
