high zinc synthetic
Old Aug 15, 2012 | 07:32 PM
FRITZM's Avatar
FRITZM
Default high zinc synthetic
Anyone heard of and/or used this product. Comments, suggestions?
http://www.joegibbsdriven.com/produc...ance/ls30.html
Old Aug 15, 2012 | 09:21 PM
RoadWarrior911's Avatar
RoadWarrior911
6th Gear
I don't know if this will help answer your question but here is a writeup from someone who has spent years on this subject for the VW and Porsche communities and highly recommends JGD products, although he is not discussing the specific JGD viscosity you are asking about but rather a couple of others. Owners of those European cars have the same concerns about ZDDP levels as Corvette owners so his comments are worth consideration.
http://www.lnengineering.com/joegibbsracingoils.html
Old Aug 15, 2012 | 10:13 PM
billla's Avatar
billla
St. Jude Donor '14
There's no need for high ZDDP for a roller-tappet cam...like our C5s have.
The reason for reduction of ZDDP in oil was due to the negative impact it has on catcons.
Use what's in the owner's manual
Old Aug 15, 2012 | 10:14 PM
flynhi's Avatar
flynhi
FWIW, Mobil 1 has a synthetic with zinc for high mileage cars.
Old Aug 16, 2012 | 12:07 AM
FRITZM's Avatar
FRITZM
Default Oil
What is considered high mileage. Just got my vette 2 months ago, 2000 vert, and it has 72k. Would this be considered high mileage? Would i be safe to, and should i use, a high zinc synthetic?
Old Aug 16, 2012 | 12:21 AM
lionelhutz's Avatar
lionelhutz
Some people swear by expensive oils like that. For $11 a quart I'll pass and just pick up a good synthetic for 1/2 that cost when it's on sale.
Old Aug 16, 2012 | 01:54 AM
_r2h's Avatar
_r2h
Just get the M1 high mileage oil, or 0w-40 oil if you want high zinc.
Old Aug 16, 2012 | 02:08 AM
flynhi's Avatar
flynhi
I think the Mobil 1 High Mileage container label says for cars with more than 75,000 miles.
Old Aug 16, 2012 | 02:20 AM
high wire's Avatar
high wire
I just did a google search on this.There seems to be a issue with ZDDP and the catalytic converters.
Old Aug 16, 2012 | 06:59 AM
baxsom's Avatar
baxsom
Yes the phosphorus in ZDDP will clog a cat. ZDDP is only there to serve as a barrier between the cam lobe and flat tappet lifter. A roller cam doesnt need that barrier.
Old Aug 16, 2012 | 05:53 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Old Aug 16, 2012 | 06:28 PM
_r2h's Avatar
_r2h
I'll take any protection ZDDP has to offer (if any) over cat life. Rebuilding and replacing an engine is usually more expensive that a cat replacement.
My 2c.
Old Aug 16, 2012 | 07:12 PM
baxsom's Avatar
baxsom
My 2c.
for a roller cam, it will offer no more protection than the oil spec'd by GM for a LS1. Go to the C3 forum and read up on what it actually does.
Old Aug 16, 2012 | 07:17 PM
billla's Avatar
billla
St. Jude Donor '14
My 2c.
The only place ZDDP matters is at the cam/lifter interface with a flat-tappet cam.
The benefit to a C5 is zero - absolutely none...and you should probably go price factory replacement cats.
Many, MANY C5s go 100's of thousands miles with - oddly enough - exactly the oil that's specified in the owner's manual.
Old Aug 16, 2012 | 07:31 PM
_r2h's Avatar
_r2h
http://en.wikipedia.org/wiki/Zinc_di...e#Applications
See that bit about big end bearings? Also as a corrosion inhibitor? ZDDP is many uses other than as a sacrificial coating on flat tappets. Stating the benefit to a C5 is "zero" is quite a large statement.
That being said, I'll take my chances with a clogged cat.
Old Aug 16, 2012 | 07:41 PM
billla's Avatar
billla
St. Jude Donor '14
Not what I said. I said ZDDP beyond what's in the oil spec'd for our LS engines has zero benefit. ZDDP has been continually reduced and is now less than 600 PPM in the oils the engineers that built our cars spec'd.
Does anyone - anyone at all - see a durability issue with the LS engines running the oil they were designed for? No. None at all. Mine is pushing 100K daily driven and auto-x'd on a straight diet of Mobile 1.
But if somoene wants to out-think the GM engineers that designed the LS and selected the oil...go for it. It's your car and you can do what you like
Old Aug 16, 2012 | 08:01 PM
_r2h's Avatar
_r2h
I don't see any statement in there that could even remotely mean " said ZDDP beyond what's in the oil spec'd for our LS engines has zero benefit."
Engineers do a great job of picking a single best oil that works in most situations. One oil is not best in all situations. If you want to partake in the 5w-30 M1 is the "omg best oil for c5 eva!" Koolaid you go right ahead sir. I use M1 0w-40, because frankly it is spec'd as an amazing oil, better in all regards (additive package, HTHS rating, etc) compare to the M1 5w-30.
My cats have 100k on them, so anything I get beyond their already reached rated life is simple gravy.
These oil threads always turn into crap slinging. To sum it all up, people will use whatever oil they want.
To high zinc synthetic
Old Aug 16, 2012 | 08:28 PM
billla's Avatar
billla
St. Jude Donor '14
*sigh* The thread is high ZDDP oils for the C5. I said - and still do - that the additional ZDDP has zero value for the C5.
As for M1; I made no such observation; my owner's manual doesn't say Mobile 1 that I can see.
I'm facinated - you have 100K miles on M1 with <= 600 ppm ZDDP and now you've decided twice that amount is going to help with something based ojn a wikipedia article?
These oil threads get interesting because folks are always looking for the secret sauce and there isn't one. Use the oil in the manual. Change it when the DIC says you should. Done.
Old Aug 16, 2012 | 08:37 PM
lucky131969's Avatar
lucky131969
....yet another stupid f$%king oil thread......
Old Aug 16, 2012 | 11:27 PM
ZZ06's Avatar
ZZ06
Did you design the LS1.....I dont understand where you come off thinking that way. The engineers DESIGNED this motor to last 200k using M1 5w-30 and 10w-30 (depending on climate) Owners manuals arent just for shelves you know.....wheres Evil when you need him.
