(T56 trans) Best mainshaft available for the T56 ?? OEM C6Z06 30 spline? Thanks
Cruise-In VII Veteran
Replacing the mainshaft in a C5 T56.
1. What's the best/strongest available part?
2. OEM C6Z 30 spline mainshaft and EDM the pinion gear?
3. Of course the 30 spline mainshaft/2006 up tail housing could be used with the C6Z06/ZR1 diff and C6 cradle/LCA's/Pfadt mounts, this setup has been proven since 2009 (Bret Bradbury has a great writeup in C5 F/I)
What's the weaker link, OEM T56 27 spline mainshaft or the OEM pinion carrier support?
I have replaced trans where both have broken and I've also seen cases where ONLY the mainshaft has snapped(aft end), leaving the diff in serviceable condition after a complete teardown and trip to the parts washer
When my mainshaft broke back in 2006, I replaced it with a 9310 27 spline hardened shaft I got from G-Force and haven't had a problem with it since and I have 100 more rwhp now. HTH
Jimbo
Ask Rick; see what he thinks?
Georgies (04-04-2018)
I would say either route is a good way to go, but if you do not do other modifications such as a trans brace and/or the pfadt mount to prevent side to side play, then you could end up breaking whatever you put in it, or the trans/diff cases regardless.
I replaced my broken mainshaft once, did not add anything else bracing wise, and broke the mainshaft as well as the intermediate case 2 weeks later on a 1-2 shift.
I have seen 30 spline c6z shafts break in c5's as easily as a 27 spline.
When it comes down to it, this is really stupid old school ****. Driving that much force with a roughly 1" diameter shaft is ridiculous. I have never been quite fond of the setup but it is what it is.
