C6 GS/ZO6 calipers & rotors on a C5 Coupe
I want to start rounding up parts necessary to install C6 GS/ZO6 6-piston calipers and OE rotors onto a 2001 C5 Coupe. Namely, the most cost effective/best place to get the factory parts needed. Dealer pricing is steep. Im also looking to understand any fitment issues, special parts needed (adapter plates, fittings, etc). I have C6 ZO6 replica wheels already, so should be good on wheel clearance.
Input would be great. Thanks
If you have C6Z Replicas in a C5 offset I doubt they will work. The wheel may hit the face of the caliper, may need spacers. I have the C6Z brakes but also a set of custom HRE wheels and they fit very tight. I will be dry fitting a set of Ace Slick 18x19 C6 offsets this weekend and will see how that goes.
KillSw: so did all the C6 ZO6 brake hardware fit onto the spindles ok? no special adapters or other hardware needed? Did you simply order the latest model year GS or ZO6 calibers & rotors from GM or a discount AM supplier? My replicas are not C5 offsets as I have tubbed wells. Thanks
I am personally a huge fan of the Hawk HPS compound. Been using them on most of mine and families vehicles for years. As much as you would think they wear out, the actually last a long time. The ceramic ones they have are also good and produce even less dust/more life but don't have as much bite.
