Active Handling Problem
Old Aug 19, 2012 | 06:05 PM
LSFREAK's Avatar
LSFREAK
Default Active Handling Problem
I Just recently got everything back together after having the motor redone. Now I have and active handling problem. When I'm in reverse it sometimes will go off and when I turn all the way to the right when I'm going forward. I don't know what it could be? Did I miss any sensors while putting the cradle back in or what. Could you forum memebers please help me out.
Old Aug 19, 2012 | 06:48 PM
LSFREAK's Avatar
LSFREAK
Yes I did have some codes but I just erased all of them like the video was doing
Old Aug 19, 2012 | 06:53 PM
87SAM's Avatar
87SAM
Quit that! Post up the codes.
Old Aug 19, 2012 | 07:08 PM
LSFREAK's Avatar
LSFREAK
Alright alright I'm gunna do a little driving tonight to put some miles on the break in anyway so I'll see if the come back on and I'll throw them up on here.
Old Aug 20, 2012 | 10:55 PM
dannyman's Avatar
dannyman
Old Aug 21, 2012 | 12:25 AM
LSFREAK's Avatar
LSFREAK
58 sdm b0026 h c that's the code that stayed on
Old Aug 21, 2012 | 09:17 AM
03WhiteConv's Avatar
03WhiteConv
Did you change anything in the suspension? Lower the car, change the attitude?
I have read several folks have issues after making those adjustments.
Old Aug 21, 2012 | 10:38 AM
LSFREAK's Avatar
LSFREAK
Freshened the short block, built the tranny, spec 3+ clutch, fast intake and throttle body, new cam that's all
I did.
Old Aug 21, 2012 | 01:36 PM
LSFREAK's Avatar
LSFREAK
I dropped the cradle and yea I'm pretty sure it's installed right. I had a lot of codes but deleted them all after watching that video while deleting it the one stayed on.
Old Aug 21, 2012 | 01:52 PM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by 8VETTE7
Did you pull the motor from the bottom? Drop the rack out?
If so are you certain the rack is properly reinstalled and steering wheel correctly centered.?
With no codes and the symptoms you are stating, sounds like steering wheel is not centered properly or the steering wheel sensor is going out.
Several reports of that sensor going bad and not reporting codes.
In case you missed it 8VETTE7, this is the code from an earlier post.
Old Aug 21, 2012 | 02:33 PM
87SAM's Avatar
87SAM
B0026 is a airbag issue. I think 8VETTE7 may have identified the issue.
Old Aug 21, 2012 | 03:29 PM
LSFREAK's Avatar
LSFREAK
Well the car has a sparco racing steering wheel. So I guess there's the answer to why that one is on
To Active Handling Problem
