HVAC code B0338 97 Auto Targa
Old Aug 21, 2012 | 07:44 AM
seegeer's Avatar
seegeer
Default HVAC code B0338 97 Auto Targa
Hello,
I had the AC recharged, no leaks but now the green ac light just blinks, pulled the codes and B0338 came up which is inside air temp sensor open. How is that fixed? thanks
Old Aug 23, 2012 | 08:47 PM
seegeer's Avatar
seegeer
ttt
Old Aug 23, 2012 | 10:07 PM
Vicarious.'s Avatar
Vicarious.
the cabin temperature sensor is located inside the little plastic pop out tab that is on your driver side dash - right next to the ignition switch. It is very easy to access.
Sensor open usually means 1 of 2 things.....1) the sensor has failed....or 2) the wiring to the sensor itself has been damaged or has come loose.
Old Aug 24, 2012 | 07:48 AM
seegeer's Avatar
seegeer
given the fact that i shattered that sensor in there might be the reason it doesnt work! i broke it when i first bought the car a few months ago trying to put the dash back together and i had no idea what it was. i even bought the 4 repair manuals off of a member on here and i couldnt find it in there....thanks a bunch for responding, now the hunt is on for a new one...
thanks again
Spence
To HVAC code B0338 97 Auto Targa
