Shift Kit
Old Aug 22, 2012 | 12:55 PM
Vic'sVette's Avatar
Vic'sVette
Default Shift Kit
2001 Coupe, 93k miles, M30. I am having trans filter and fluid change done. I was thinking that I might as well install a shift kit, too. From what I've been reading, Transo is good.
I see the Transgo shift kit does not require trans removal to install but the reprogramming kit does. I do not want to have to remove trans at this time. Will I feel a difference with the standard shift kit???
I just would like to have quicker shifts when manually gearing up & down when I'm playing in the hills. A firmer shift would be nice, too. Will I get this with the standard shift kit???
Thanks in advance.
Old Aug 22, 2012 | 01:01 PM
3boystoys's Avatar
3boystoys
Think you can adjust shift points electrically via the OBD port.
Old Oct 3, 2012 | 12:31 AM
2SlowinTO's Avatar
2SlowinTO
Did you put the shift kit in??
And if so, how do you like it??
To Shift Kit
