Army friend called with this problem
Old Aug 22, 2012 | 03:54 PM
bobby777's Avatar
bobby777
Default Army friend called with this problem
He has been gone for 4 years--stored a 2003 z06- car has 12,000 miles and stored all this time--car was started once in a while-liely too much idling-- but not driven--he says its hard to start--took it for a ride and popped alittle bit at around 6300 in first gear--im guessing old gas and carbon build-up--i said drive it for 100 miles and ill bet it comes out of it--any other suggestions? Thx.
Old Aug 22, 2012 | 04:26 PM
MotoMike02's Avatar
MotoMike02
I would have changed all fluids, inspected all rubber boots and seals, checked the intake to make sure nothing made a home in it. Topped off the fuel with some 93 and some additive and cleaner as start. If it still pops suggest cleaning the entire fuel system out and some new plugs. I do that except changing all fluids after my car sits for only 6-7 months when im gone.
Old Aug 22, 2012 | 04:45 PM
bobby777's Avatar
bobby777
Originally Posted by 8VETTE7
Seems to me that red line is 6000 (unless this is a prepared car with a higher RPM limit). Any strange things happening at above 6000 RPM is likely due to the soft rev limiter doing its job. ie limiting the RPM's.
Red line on a Z06 is 6500--anyway the popping im sure is carbon with old fuel--he did change oil and filters---the car was stored in a climate garage but started often--im thinking too often and just built up carbon and needs to be driven hard for awhile--
Old Aug 22, 2012 | 05:18 PM
oh1vette's Avatar
oh1vette
4 years - Man thats ALONG time
Tell your buddy Thanks for his service
Hope its as easy as you say....
Sitin for 4 years and bangin off the rev limiter already - I'm guessin he missed drivin it
Vetterthanyou2's Avatar
Vetterthanyou2
Old fuel and carboned up parts. Hell, maybe a rats nest blocking the air intake!? After sitting THAT LONG Id start with fresh expendables before I even started it.
Old Aug 22, 2012 | 05:37 PM
bobby777's Avatar
bobby777
Thats exactely what he did--needed that speed---im sure burning that old gas out and fuel inj. cleaner will bring the car back 100%
Old Aug 22, 2012 | 05:45 PM
Vicarious.'s Avatar
Vicarious.
hope he put stabil in the tank before he left...that would have helped some.
Old Aug 22, 2012 | 06:11 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Most of us know how Corvettes are hard on batteries. Maybe his is not up to par, and giving him voltage fluctuations...
Old Aug 22, 2012 | 07:05 PM
kalayaan12's Avatar
kalayaan12
Mice sure do love Corvettes...
I came back home from overseas once and was dying to take mine out for a drive, only to find that a mouse decided to chew up some underhood wiring and make a nest under the LH engine cover.
Mothballs scattered under the car seemed to help, or so I thought. Over the years I've found mouse nest "fluff" and droppings packed in under the battery tray, and up behind the rear shock brackets.
They are really nasty little critters!
Jeff
Old Aug 22, 2012 | 09:11 PM
andrec10's Avatar
andrec10
Jeff
They really seem to hate dryer sheets more than anything!
Old Aug 23, 2012 | 01:19 AM
SBCGENII's Avatar
SBCGENII
I would send the injectors out to me cleaned.
Old Aug 23, 2012 | 01:54 AM
Supercharged111's Avatar
Supercharged111
Jesus you guys are picky. I'd just fill up with a bottle or 2 of fuel system cleaner and keep beating on it. I can't imagine it was stored with a full tank of gas.
Old Aug 23, 2012 | 09:13 AM
cwis9992's Avatar
cwis9992
run a can of seafoam through that bad boy and just go with it
or 2...
or more
Old Aug 23, 2012 | 02:24 PM
bobby777's Avatar
bobby777
or 2...
or more
He ran a can of heet and a fuel system cleaner drove it 125 Miles hard--car runs like the day he bought it--1 code about 02 sensor did show up--cleared it and everything is fine--thx guys for your suggestions--
Old Aug 23, 2012 | 05:01 PM
oakvillec5's Avatar
oakvillec5
Nice!!!! Glad its running properly....after 4 years, it needs to breath in the fresh air!!
To Army friend called with this problem
