Lifting pucks
Old May 31, 2002 | 12:02 AM
eastco's Avatar
eastco
Default Lifting pucks
I seen some talk on lifting pads for C5 I found some in the store and they are a nice tool to keep the lift off the body (if you have a car lift you need to order 4) just in case anyone was wondering :smash: :smash: :flag
Old May 31, 2002 | 12:51 AM
CAU-LLC's Avatar
CAU-LLC
Default Re: Lifting pucks (eastco)
We have ours on special on the Mall
http://store.yahoo.com/corvetteforum/setjacpuc.html
Check out the instructions in our C5 Tips & Tricks section on our site.
Jim Booth / Corvette Accessories Unlimited http://www.CAU-LLC.com
Old May 31, 2002 | 12:59 AM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
went to a chevy dealer today, they had a c5 on the lift getting an oil change, they didn't use any pucks.
Old May 31, 2002 | 01:07 AM
Bill Reid's Avatar
Bill Reid
Default Re: Lifting pucks (c5edko)
...they didn't use any pucks.
... not good :nonod:
Old May 31, 2002 | 09:39 AM
ncvetteman's Avatar
ncvetteman
If your lifting on the crossmembers with a standard floor jack you just need a block of wood. "Pucks" are from lifting at the corners, according to the owners manuel it recomends lifting at all 4 points at the same time (altough some members do lift one at a time, its not recommended), they are really designed for 2 Post lifts. For jack use, the owners manuel recommends lifting from the crossmembers, where you would just use a piece of thick wood to even the load out a little.
[Modified by ncvetteman, 10:05 AM 5/31/2002]
Old May 31, 2002 | 10:25 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Lifting pucks (ncvetteman)
I made my own with hockey pucks and they've worked very well.
Old May 31, 2002 | 01:33 PM
lostsoulny's Avatar
lostsoulny
Default Re: Lifting pucks (rschiltz)
I had my car lifted with a floor jack behind the front tire, no problem just make sure you place it behind the rocker panels. also had it on a lift just make sure the mechanic is careful where he places the pads.
Old May 31, 2002 | 04:24 PM
darkmercury's Avatar
darkmercury
2 sandwiched Hockey pucks work good!!! They only cost $1 per puck!!!! :yesnod:
Old May 31, 2002 | 04:33 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
homeade with hockey pucks:
http://www.97vette.com
Old May 31, 2002 | 04:56 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Lifting pucks (darkmercury)
Why two pucks together I use one puck amd it works fine.. but themI could not get two under there anyway with my car being lowered it cost me 5 dollars to make 4 lift pucks with eyes to lock the puck to the frame
Old May 31, 2002 | 06:32 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Lifting pucks (Evil-Twin)
DarkMercury; do you have to use 2, or is that just your preference?
I was able to use just one hockey puck ($1 each at Dick's Sporting Goods) and have about 3/8" clearance from the jack to the rocker panels.
I'm wondering if your jack has a deep pocket type pad...
[Modified by Mike Mercury, 5:35 PM 5/31/2002]
Old May 31, 2002 | 06:38 PM
BLUBYU2002C5's Avatar
BLUBYU2002C5
Default Re: Lifting pucks (Mike Mercury)
I'll agree go with hockey pucks ---- 4 @ $1.00/each :yesnod: :yesnod:
Old May 31, 2002 | 06:54 PM
NICEDRV's Avatar
NICEDRV
same here, went to play-it-again sports and bought 4 pucks for a $1 ea.
Old May 31, 2002 | 08:12 PM
HOCKEY's Avatar
HOCKEY
Default Re: Lifting pucks (kewlbrz)
kewlbrz,great pics of how to do
Old May 31, 2002 | 09:24 PM
eastco's Avatar
eastco
Default Re: Lifting pucks (CAU-LLC)
These are the ones I bought and the puck idea is nice BUT I bought these to lift customer cars with this is made with this in mind of protecting the car I would like to think if you were a doctor and I came to you that the best care would be taken to assure I am taken care of properly We are just being carefull thanks for the input
Old May 31, 2002 | 09:40 PM
SoCal C5's Avatar
SoCal C5
went to a Chevy dealer today, they had a c5 on the lift getting an oil change, they didn't use any pucks.
I had a dealer do that to my car. I just won a small claims case against them for the damage they caused.
I bought a set from Fichtner Chevrolet (supporting dealer, see my signature)I now carry them with me at all times in case I need unexpected service (i.e. flat repair) while on the road. Chances are that if you need something unexpectedly the shop you end up at won't have lift pucks.
Old Jun 1, 2002 | 03:12 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Lifting pucks (SoCal C5)
O.K. I made my own and have never used them.
Old Jun 1, 2002 | 05:46 PM
Oldvetter's Avatar
Oldvetter
Default Re: Lifting pucks (wallstAL)
I use the solid aluminum ones. I didn't like the flex I got with "hockey pucks", especially when I lifted high.
To Lifting pucks
