First Oil Change, Is This Normal?
Old Aug 23, 2012 | 10:42 PM
C5Natie's Avatar
C5Natie
Default First Oil Change, Is This Normal?
Ive been driving my new LS3 for 800mi. (20k mi used shortblock) I did the first oil change today to see how the oil looked. The oil that came from the filter concerned me a bit. It had a slight greyish metallic look to it. Im paranoid from when I lost a bearing on my old motor so I dont know if this normal from the new parts breaking in or what. New parts include the heads, valvetrain, cam, oil pump and timing chain. I used a lot of assembly lube as well. What do you guys think?
Old Aug 23, 2012 | 11:09 PM
CactusCat's Avatar
CactusCat
Won't hurt to double check everything but more than likely, its the assembly lube that has mixed with the oil (as per your statement).
Old Aug 23, 2012 | 11:22 PM
C5Natie's Avatar
C5Natie
I ran a strong magnet through it. Its strong enough to pick up a ratchet. Didnt see any metal on it. None was on the plug as well.
Old Aug 24, 2012 | 07:29 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
all should be well?
Old Aug 24, 2012 | 07:47 AM
SS2001SS's Avatar
SS2001SS
Do a couple more changes and watch the oil. It should clean up after you get the assembly lube flushed out.
Old Aug 24, 2012 | 10:36 AM
NukeC5's Avatar
NukeC5
From what Ive seen it is normal. Break in oil and just new components will make a different color and smell at first.
Although If you only put 800 miles on it, I would re add break in oil... I think it takes longer than that to set in the piston rings. Then once you have reached normal mileage for a change, you should be good to go to normal oil.
Never-mind... sounds like the block was not redone... Did you have break in oil in at all?
Old Aug 24, 2012 | 11:28 AM
dadaroo's Avatar
dadaroo
What was the color of your break in lube? Most I have used in years past were grey in color. A magnetic will not pick up bearing material unless you go to the steel backing which if you were there the motor would be seized. I don't think you have a problem.
Old Aug 24, 2012 | 12:51 PM
sunchaser73's Avatar
sunchaser73
You could send a sample of the oil to Blackstone Labs, along with a clean sample of the oil you used (and the assembly lube wouldn't hurt either). They can analyze the used oil and provide results and advice/conclusions.
Old Aug 24, 2012 | 12:55 PM
JohnJ@Texas-Speed's Avatar
JohnJ@Texas-Speed
Premium Supporting Vendor
This sounds normal to me. After doing a swap like that there will be a lot of excess fluids and lube that will be seen in the first couple oil changes. As long as oil pressure is good and you weren't able to find any metal in the pan I think you are alright.
Old Aug 24, 2012 | 07:16 PM
C5Natie's Avatar
C5Natie
Thanks for your help guys. I used a convetional oil for the first 'break in' oil. I used the Lucas assembly lube which is a green color. The oil was pretty clear, as in clean, but the shimmer to it under the light was a greyish green metallic hue. With the 5w40 I put in yesterday my oil pressures today were 50+psi at cold startup, 40+psi hot idle (220*) and 55-60psi cruising around (1800-2000rpm). I plan to send a sample of the next oil change to Blackstone and see what they say.
Old Aug 24, 2012 | 09:59 PM
NukeC5's Avatar
NukeC5
Your pressure readings are right on and honestly everything seems normal to me. But sending it in is a great way to be sure. Better safe than sorry right?
Old Aug 25, 2012 | 01:33 AM
C5Natie's Avatar
C5Natie
Very true Nuke. I wanted to wait for this next oil change just to make sure what I saw wasnt just assembly lube and stuff from the new parts. $25 for a uoa is cheap insurance and peace of mind.
To First Oil Change, Is This Normal?
