C5 drivetrain loss
Old May 31, 2002 | 01:19 AM
BiZ's Avatar
BiZ
Default C5 drivetrain loss
What is the % of drivetrain loss for the C5?
Thanks,
Jason
Old May 31, 2002 | 01:34 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: C5 drivetrain loss (BiZ)
~15% for manuals
~17% for automatics
to get crank HP, take RWHP and divide by .85 (manauls) or .83 (autos)
Old May 31, 2002 | 02:30 AM
akw408's Avatar
akw408
Default Re: C5 drivetrain loss (kewlbrz)
I believe it's a tad bit higher than that, but realistically it's not a fixed percentage.
Old May 31, 2002 | 09:51 PM
ruking1's Avatar
ruking1
The range seems to be 11-20%
Old Jun 1, 2002 | 03:05 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
~15% for manuals~17% for automaticsto get crank HP, take RWHP and divide by .85 (manauls) or .83 (autos)
This has been the standard since I have been here, or the A4!
~15% for manuals~20% for automatics to get crank HP, take RWHP and divide by .85 (manauls) or .80 (autos)
Old Jun 1, 2002 | 04:28 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: C5 drivetrain loss (wallstAL)
:yesnod:
[Modified by MDL-01C5, 3:28 AM 6/1/2002]
Old Jun 1, 2002 | 02:48 PM
Gary2KC5's Avatar
Gary2KC5
~15% for manuals
~17% for automatics
so drivetrain loss is greater in manuals?
400rwhp/.85=470fwhp vs. an auto which would be 400rwhp/.83=482fwhp
therefore all stock A4's have a hp advantage over M6's???
I guess you could say that a stock car has the hp rated @ the flywheel so the equation works to show A4's have less rwhp but in the real world we don't get data from flywheel dyno's...just rw dyno's.
so when I dyno next to an A4 and come out with identical #'s then the A4 has more fwhp???
[Modified by Gary2KC5, 12:53 PM 6/1/2002]
Old Jun 1, 2002 | 02:58 PM
CliffB-99's Avatar
CliffB-99
Default Re: C5 drivetrain loss (Gary2KC5)
~15% for manuals
~17% for automatics
a 470 hp motor in a manual = 400 at the rear wheels (400 rwhp/.85 = 470 hp)
a 470 hp motor in an automatic = 390 @ the rear wheels (390 rwhp/.83 = 470 hp)
The manual is more efficient at transferring power to the rear wheels. :smash:
[Modified by CliffB-99, 1:00 PM 6/1/2002]
Old Jun 1, 2002 | 02:59 PM
kewlbrz's Avatar
kewlbrz
~15% for manuals
~17% for automatics
No, I think your misunderstanding. Your using an example that starts with 400RWHP for both cars. Thus since and A4 has more parasitic loss than a manual, you have to have MORE HP for an A4 at the crank, to achieve the 400RWHP figure relative to an MN6. Your example in fact proves the MN6 is more efficient.
Old Jun 3, 2002 | 07:23 PM
Gary2KC5's Avatar
Gary2KC5
...Your using an example that starts with 400RWHP for both cars...
I can see how the equation works when you know the FWHP and want to calc the RWHP.
My misunderstanding is when you only know RWHP, like on a dyno.
On my last dyno run it resulted in 355 rwhp. I noticed that WallstAl's sig also shows dyno #'s of 355 but he has an A4. therefore what your saying is that the A4 has more FWHP to generate the same RWHP?
Old Jun 3, 2002 | 08:08 PM
kewlbrz's Avatar
kewlbrz
Correct. An A4 needs more FWHP, to achieve an equal amount of RWHP compared to an MN6.
When calculating FWHP Loss, you subtract a percentage from the crank.
An A4 looses more than a MN6 by the time it reaches the rear wheels.
When calculating RWHP, you take the inverse proportion. To simply add (for instance in an MN6 355rwhp * 1.15) would be wrong. You must take 355rwhp / .85
[Modified by kewlbrz, 6:09 PM 6/3/2002]
To C5 drivetrain loss
