HELP with Hyper flash (after module installed) --PLEASE!?
Old Aug 26, 2012 | 02:47 PM
rebelde's Avatar
rebelde
Default HELP with Hyper flash (after module installed) --PLEASE!?
Hello, I am pretty new to working on my car, and have a big issue.
PLEASE help if you can, I dont want to drive around with this PAIN ,and cant take it all out. read below hyoperfals when E.brake let OFF...
I installed, LED's in 100% of my car, interior, and exterior, including a/c, instrument cluster, etc. KNOWING that I would need the hyperflash module, and the LED taillights from american flyer already had the resistors I believe.
SO, after installing the harness module, and all bulbs, in all locations, and putting everything back together, the car looked awesome, BUT the directional arrows, stayed lit in the instr. cluster, BUT there was NO HYPER flash, WITH THE PARKING brake on........ THEN I put it doen to test drive the car, and it went back to normal hyper flash, like when I had just the front markers, and inside bulsbs, w/o the a/c and instr cluster done, ??????? the only way it stops, is to PUT THE multi switch ON in parking light or head light MODE, BUT....
the directional arrows inside still stay lit,and the blinkers, (turn signals and hazzards) do not flash as intense, and are slow if at all.
PLEASE help if can, I have come way to far to just say, take it all out.... has ANYONE else done this, I cant be alone here.
CARLOS
