A4 tranny service
Old May 31, 2002 | 11:34 AM
aces's Avatar
aces
Default A4 tranny service
Exactly how much fluid is needed to refill after dropping the pan ?? How much if you just pull the plug and refill ? I'm doing a full service, then I wanna drain and refill couple of times. :cheers:
Old May 31, 2002 | 11:39 AM
RedLandRocket's Avatar
RedLandRocket
Default Re: A4 tranny service (aces)
I dropped the pan and it took about 2 1/2 quarts to fill up to the drain plug.
Then almost another 2 quarts to fill it up with the engine running. I did spill a little.
I heard it takes 10-12 quarts to do a full flush.
Old May 31, 2002 | 12:47 PM
DAWS C5's Avatar
DAWS C5
Aces. RedLand is right. You need to find someone who can power flush the transmission to get all the old fluid out. This will be much more effective than draining/filling multiple times.
:seeya
Old May 31, 2002 | 05:02 PM
aces's Avatar
aces
Default Re: A4 tranny service (DAWS C5)
:seeya
You may be correct but , I'd rather spend the $99.00 on more fluid than labor. $ 99.00 is the going rate for a flush and the thought of a kid useing non snap-on wrenches on my car scares me.
Old Jun 1, 2002 | 03:14 AM
aces's Avatar
aces
And even if I flush , I still need to change the filter.
Anyone else have any firsthand experience ? :cheers:
Old Jun 1, 2002 | 11:48 AM
DAWS C5's Avatar
DAWS C5
I've yet to do my vette but used a Jiffy Lube for a power flush on my last car. Jiffy Lube is not my first choice for the vette but if I have to, I plan to talk with the manager first to insure they have an experienced person do the work. Then I will watch over their shoulder. In the meantime I am looking for a good shop that can do this. Anderson's Chev in Menlo does not do power flushes. Will ask other locals for recommendations. Still have
about 10K miles before I plan to do this.
:seeya
Old Jun 1, 2002 | 01:56 PM
aces's Avatar
aces
Carl's on capitol expressway in SJ does them
Old Jun 2, 2002 | 03:36 PM
aces's Avatar
aces
ttt :cheers:
Old Jun 3, 2002 | 09:59 AM
IMQUIK's Avatar
IMQUIK
Save time! Get ya 14 quarts of Amsoil ATF,head out to find a shop that has the tranny service pump system. And ALL of your ATF will be fresh. :yesnod: :smash: :yesnod: :smash: :yesnod: Had mine pumped in for$50 I brought my own AMSOIL (at cost :yesnod: )
[Modified by tshac, 9:01 AM 6/3/2002]
Old Jun 4, 2002 | 01:23 PM
DAWS C5's Avatar
DAWS C5
Thanks aces. You just saved me from looking further. Carl's has a good reputation.
:seeya
To A4 tranny service
