Z06 rear brake duct template needed...
Old May 31, 2002 | 06:53 PM
Chris99FRC's Avatar
Chris99FRC
Default Z06 rear brake duct template needed...
I just ordered a set of rear ducts for LAPD and was wondering if anyone had a template that they used to cut the holes?
Old May 31, 2002 | 07:50 PM
movinup's Avatar
movinup
Default Re: Z06 rear brake duct template needed... (Chris99FRC)
I think most everyone made their own template out of
light weight cardboard. It's not very hard to do. I have
heard that Ecklers gives you one when you buy the ducts
from them.
Old May 31, 2002 | 10:10 PM
J99FRC's Avatar
J99FRC
You've got mail! :cheers:
Old May 31, 2002 | 11:35 PM
Bill Reid's Avatar
Bill Reid
Default Re: Z06 rear brake duct template needed... (J99FRC)
Chris, we created a template by removing the ductwork on a Z06 and tracing the body. We feel our template is accurate. Keep in mind that, as with any template, it should be created on the conservative side... better to trim here an there than to over do it and have an exposed gap. Also, If you look at the duct panel that bolts to the side of the car the studs are kinda pointed in towards each other. Even on a factory Z06 the holes on the body do not appear to line up with the studs on the ductwork. Its tight but a little flexing and it will slide into place. Give us a call if you want us to send a template to you :)
:cheers:
Old Jun 1, 2002 | 03:28 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
You can also try the search, I have seen this many times!
To Z06 rear brake duct template needed...
