Air pump and wideband
Yes it will, but only at start up. The air pump only stays on for about a minute or so to light the cats. After that it may start once in a while to fire up the cats when driving. It is noticeable, but you realize what is happening.
A plus to this is that you can see if your check valves are getting sticky. Mine are so I have to goose the accelerator a few times to get them open, otherwise I will get a check engine light. They typically fail at approximately 40-50k miles.
