I have a set of dart heads for my LS6 with 58cc comb chambers. I was told that was a 11.6 CR but by my math with a .051 head gasket I come up with 11.25 CR which I feel better about. I used a deck clearance of .006 and a 0 piston dish/dome.
I know my math must be off some as I figured the stock CR at 10.42 when advertised is 10.5
To get 11.25:1 did you use a 3.90 boar and 3.62 stoke? Sorry, dont feel like doing the math again.
I have just seen allot that the real boar and stroke are 3.898 and 3.622. So I use those figures in my calculations.
I used the 898 and 622 numbers, I actually also got 11.24:1
I need to verify this, but I think I found the discrepancy. I put in a .006 deck clearance, but I think the piston actually goes above the deck so deck clearance should be -.006 I even read -.008 somewhere under full rpm load.
Anyone else care to comment on this?
You are right!!! With .006 protruding I came up with 11.6:1. So yes, they where correct in telling you that ratio. I cant believe I missed that! Good catch
Something is still wrong. Using those same figures the stock CR would be 10.64:1
That very well may be the ratio. Stock is harder to calculate because it changes. Remember, there are slight fluctuations in DC, (like -.006 or -.008) and even some different figures that I have seen. 97-00 used a different head gasket thickness than 01-04 did.
All the little differences and changes can give you anywhere from 10:1 maybe up to 10.6... It depends on the numbers used in the calculations. Its hard to know for sure what is in the engine without actually using a micrometer and dial indicator on every part.
The figures we use are the generally accepted ones from forums etc. Most people would calculate with a 3.898 boar, a 3.622 stoke, a .052 gasket thickness, and a -.006 DC. But they are not necessarily the exact specs in every LS1.
