04 magnetic shocks please help
Old Sep 12, 2012 | 06:53 PM
love's Avatar
love
3rd Gear
Default 04 magnetic shocks please help
hi, i live in orange county, california and have 04 Convertible with the magnetic suspension option.
with less than 30,000miles sitting in the garage most of the tims, they socks already went bad - so my machanic told me - the socks are covered with black dust that looks like copy machine toner...
anyway, the original oem parts too much and i like to put the regular shocks without the magnetic option - i learned in the forum and thanks to the forum!
problem is i don't know where to take it, who knows how.
please let me know a nice place i can trust the work.
i am close to huntington beach, fountain valley, seal beach, those area...
i'd much appreciate your help in advance!
drive safe and enjoy life, everyone!!!
Old Sep 12, 2012 | 07:29 PM
love's Avatar
love
3rd Gear
Default Thank you so very mcuh.
Originally Posted by 8VETTE7
The tough part is Deleting the option in the BCM. You need someone with a TECH II that can follow the instructions below exactly:
Here is the procedure that worked!
1. Hook up your Tech 2, turn the car ON, make sure the module in the rear is plugged in. DO NOT UNPLUG THIS MODULE
2. Now use the Tech 2 to delete the F45 option ( F55 option does not appear on the Tech 2 menu screen - SO - DELETE THE F45 OPTION
3. Save the new configuration
4. DO NOT TURN THE CAR OFF DO NOT REMOVE THE TECH 2 Go to the module in the rear of the car, unplug the GRAY connector - IT IS THE WIDEST ONE - leave the center and smaller black plug in.
5. Turn off the car but LEAVE THE TECH 2 PLUGGED IN
6. Remove remaining plugs from module in the rear of the car
6a Disconnect battery for at least 60 minutes
6b Reconnect battery
7. Now the moment of TRUTH - Turn the car on and verify that the dreaded - MAX SPEED 80 MPH - is gone
8. Unplug the Tech 2 - Get in the car and take it for a ride. Smile as you pass the DREADED 80 MPH and in knowing that you beat GM
Once the option is deleted, you just install the shocks of your choice.
As far as who has a TECH II in your area, start calling local tuners. Dealers will have a TECH II for certain but they may NOT want to delete the F55 option. You could start calling them and asking.
I appreciate so much! Now, I would like to know what brand and what kind of shock is recommended and how much they cost... At the mean time, I will call around to see who can delete the program.
Thanks again!
Old Sep 12, 2012 | 08:08 PM
coia96vette's Avatar
coia96vette
Check with www.gmpartshouse.com They are supporters here and have great service and pricing.
Old Sep 12, 2012 | 08:24 PM
love's Avatar
love
3rd Gear
Default Thank you again and again!
The answer to that depends upon how you drive the car. ie competition or just cruising. Costs for shocks should be in the $250 to $350 for all 4 shocks. If you plan to install them your self then no installation cost If you have someone else do the install expect a few hours labor for all 4.
How about OEM ZO6 shocks? I like to corner when I drive. I don't drive much anyway and never for a daily driver. just to have fun some times on weekends...you know.
OEM ZO6 shocks are hard? stiff? bearable?
Thank you for your kindness answering my question/s.
Respectfully,
To 04 magnetic shocks please help
