My turn, Compression ratio
Old Sep 14, 2012 | 03:35 PM
NukeC5's Avatar
NukeC5
Default My turn, Compression ratio
I was doing the math for my set up and wanted to verify that it is correct.
These are the figures I used
Boar: 3.898
Stroke: 3.622
GT: .045"
DC: -.006"
CCV: 62cc
V1= 43.22380671
V2= 0.53701582
V3= -0.071602109 (minus this number for totals. Protrudes out of boar)
V4= 3.78348691
Totals:
47.47270733
Divided by
4.248900621 =
11.17:1 compression ratio.
Also I want to know what is a safe ratio for 91 octane. If I go thinner on the gasket or mill the heads lover to 60cc and up the compression to 11.5ish:1 will that be ok?
Old Sep 14, 2012 | 03:49 PM
C5Natie's Avatar
C5Natie
Bore*
Old Sep 14, 2012 | 10:56 PM
tom01ss's Avatar
0tom01ss
Former Vendor
use 93 octane
Old Sep 15, 2012 | 01:21 AM
NukeC5's Avatar
NukeC5
Originally Posted by tom01ss
use 93 octane
91 is the highest in Cali. I don't want to purchase octane booster for every fill up..
So 11.17:1 is to high? If I get if down to 11:1 would I be ok? Ill calculate what gasket thickness to use or if I need to mill the heads to 63cc instead of 62cc.
Old Sep 16, 2012 | 12:26 AM
Coach62's Avatar
Coach62
St. Jude Donor '12
You didn't provide the bore size of the gasket, and that does make a small difference. I used 4" for the bore size and came up with 11.11
I'm assuming since your in Cali you have to run a fairly small cam, this and the lower octane reduces the CR you can use. As you know it's the dynamic CR that matters.
I'm not an expert, but I'd personally limit it to the 11:1 range, 11.1 may still be ok. Jegs has a pretty good assortment of gaskets in stock.
Old Sep 16, 2012 | 12:49 AM
RonSSNova's Avatar
RonSSNova
Folks will say choose the gasket thickness for quench value, and set the chamber size for CR. I'll be interested to hear what others say.
Ron
Old Sep 16, 2012 | 03:37 AM
NukeC5's Avatar
NukeC5
The gasket Im looking at has a bore of 3.910" so only very slightly larger than the cylinder bore. A 4" would make a small difference and lower the ratio, but I didnt calculate it because its basically the same as the bore.
NukeC5's Avatar
NukeC5
Originally Posted by C5Natie
Bore*
Dont know how I messed that one up!
Old Sep 16, 2012 | 08:47 AM
Pumba's Avatar
Pumba
Keith Black and United Engine and Machine Company offer a very good web site for calculating your compression ratio:
http://www.kb-silvolite.com/calc.php?action=comp
Fill in the blanks.
You can also calculate your Dynamic Compression Ratio with this form. Plug in your camshaft's intake closing timing.
Good Luck
Old Sep 16, 2012 | 02:38 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
That would probably explain the .06 difference between our calculations.
Old Sep 17, 2012 | 03:13 PM
NukeC5's Avatar
NukeC5
If I keep everything the same and use a .050" head gasket, it will put me at 11.03:1. Give or take a few thousands from minor differences, it is basically 11:1. This setup should be good for 91 octane correct?
To My turn, Compression ratio
