I have to replace the long tube fluid flow line on my rack & pinion. Does anyone know what the procedure would be to do so? I have looked at from both the engine compartment and from underneath the car. Both look like equipment removal to get to the far end of the line.
Ive uploaded the Rack & Pinion Schematic under C5 cutaway drawings #7 is the line that needs to be replaced
send me your email and Ill send it to you if you think you can help
Reason: adding additional information
