remove a/c condenser cam install ?
Old Sep 17, 2012 | 07:49 PM
magnoman's Avatar
magnoman
Default remove a/c condenser cam install ?
Do I need to pull a/c condenser to install cam ? Hate to have to let all the coolant out .. I have rack out and radiator , remember seeing a thread where they just laid the a/c condenser on top o motor with out un hooking lines ?
Old Sep 17, 2012 | 07:57 PM
lucky131969's Avatar
lucky131969
Originally Posted by magnoman
......remember seeing a thread where they just laid the a/c condenser on top o motor with out un hooking lines ?
I would like to see that trick. Pics please
Old Sep 17, 2012 | 08:34 PM
Goober35's Avatar
Goober35
I have done this several times in an F-body but not in the vette yet.
Old Sep 17, 2012 | 09:08 PM
magnoman's Avatar
magnoman
Ok ,, so it looks like and taking the a/c lines off ... crap ..well here its turing to fall so dont think I will be needing A/C till nest year ..
Old Sep 17, 2012 | 09:13 PM
lucky131969
Do a little research. I think you'll find most guys leave the condenser connected.
Old Sep 17, 2012 | 09:23 PM
magnoman's Avatar
magnoman
Been looking ..
Old Sep 17, 2012 | 09:37 PM
VetteNoob's Avatar
VetteNoob
Leave the condenser. You have enough room to get the cam in and out with the AC system intact.
Old Sep 17, 2012 | 09:40 PM
corvette8189's Avatar
corvette8189
Leave it in
Old Sep 17, 2012 | 09:51 PM
FRITZM's Avatar
FRITZM
Default Swap
You might want to check this site: Fritzm.
http://www.ls1howto.com/index.php?article=1
feeder82's Avatar
feeder82
it will come out without pulling the condenser but its tight i needed someone to pull it back out of the way., and i bent some fins getting it out
Old Sep 17, 2012 | 10:13 PM
warren s's Avatar
warren s
I had plenty of room. Tied the condenser up with some nylon wire ties to move it up and out of the way.
Old Sep 17, 2012 | 10:15 PM
RonSSNova's Avatar
RonSSNova
It'e easy. Take the drivers side of the condenser and tuck it behind the plastic deal that the aircleaner sits on and it will be way out of the way and it will stay there.
Ron
Old Sep 18, 2012 | 06:44 AM
LoneStarFRC's Avatar
LoneStarFRC
Leave it in. Just use a two-piece camshaft.......
To remove a/c condenser cam install ?
