P0336 Code. Video HELP
Old Sep 22, 2012 | 07:48 AM
NEMESISVETTE's Avatar
NEMESISVETTE
Default P0336 Code. Video HELP
Ok guys this is going to be a real test diagnostic ability.. lol
The car is a 2000FRC with a 408 and a Auto swap. Car has been running just fine. No misses or anything. This code popped up on the dyno after a clean run. Here is the video
http://youtu.be/OPT2tsrMdIE
So you can see that in the video the car pulled smooth no issues. Later we did another pull that I didnt get on video.. It went up smooth.. coming back down it started popping and sputtering. Then would not start and has not started again.
So here is what its acting like. It acts like its 180 degrees out of timing. just pops and sputters. It turns over fine just no starting. Getting the P0336 Crank position code.
Old Sep 22, 2012 | 07:52 AM
NEMESISVETTE
Here is what I have addressed so fare.
New crank position sensor ...........All good there.
New cam positon sensor.......... All good there.
Checked wires for visible problems Cam/Crank .........All good there.
Dropped oil. Checked it for material ............All good there.
New plugs ..............All good there.
Also pulled plugs, pulled fuel fuse and did a dry crank. ........All good there
Checked all fuses ect. ...........All good there.
Old Sep 22, 2012 | 01:25 PM
NEMESISVETTE
Originally Posted by lucky131969
....and what about the basics? Are the cylinders getting fuel? Do you have spark?
Do the rockers move with engine rotation?
Yes fuel and Yes spark.
any help is very appreciated. No bread crumbs for me to fallow on this one.
Old Sep 22, 2012 | 08:18 PM
NEMESISVETTE
I figured it out. reluctor wheel separated from crank. Time to pull engine.
Old Sep 22, 2012 | 09:03 PM
NEMESISVETTE
How is that possible? The reluctor wheel is pressed onto the crank. If the reluctor wheel was not in the correct position, you would have no spark, and no fuel.....which you already said you have both.
I will explain how its possible. The reluctor wheel is only tack welded in 2 spots. High horse power cars have been known to bust a tack and then only one is left to hold. Then that last tack lets go and the relucter just free spins. Only one of the blads came loose. So the crank position sensor was still getting a signal just at all the wrong times. Thats how its possible. In the back of my mind i had a feeling thats what it was but wasnt till I stuck my finger in the hole the crank position sensor resides did I put a finger on one of the relucter teeth and was able to move it up and down. It was still lined up just free spinning is all.
Old Sep 23, 2012 | 11:58 AM
Chicago1's Avatar
Chicago1
How did you figure that out? Mine threw that code and will fire for a second then die. I'm pulling the exhaust this weekend and changing the CPS and hope that fixes it.
Old May 18, 2014 | 02:42 AM
jmac2354's Avatar
jmac2354
I'm in the same situation. Is this thread still alive. I just had a 416 ls3 put in my Z, I'm currently 24 degrees out of timing... Demanding 50 actually running 26. It was presumed to be this reluctor causing this. Is there anyway to fix this with the motor in car. Could the wheels be positioned and tacked and welded to crank if oil pan was pulled. Can you even pull the oil pan with motor in car.
Old May 18, 2014 | 08:24 AM
sami85L98's Avatar
sami85L98
jmac: unfortunately engine has to come out to tack weld reluctor wheel to crank. May be someone will chime in who did it while engine still in the car. I did install piston Rings while short block is still in the engine bay but thats a different story and dont need a weld.
Good thing is pulling engine in our car's is not too bad. GL.
Old May 18, 2014 | 09:25 AM
dadaroo's Avatar
dadaroo
The reluctor wheel should not slip on to begin with. If it it slipped on the crank, it should have been replaced. I also do not see the correlation between HP, and breaking a weld. Whether the engine is capable of 300 HP, or 800 HP....rotation is the same....the mass is the same(of the reluctor), and the RPMs are the same.
In any case, my understanding is not important.
Good luck with the fix.
An engine that can rotate quicker places a higher sheer stress on the reluctor wheel tack welds. It kind of works like pushing on something versus using an impact with both using the same weigh object. The impact will produce a bigger dent.
Old May 19, 2014 | 11:36 PM
jmac2354's Avatar
jmac2354
What about pulling out the top. Guess I'm taking it to my buddies shop tomorrow and fixing to get started. Hopefully it comes out. Lol
Old May 20, 2014 | 03:08 PM
Chicago1's Avatar
Chicago1
I just wanted to update this mine was caused by the headers melting the harness to the CPS. I fixed the wires and gtg. OP hope all goes well
Old Jun 4, 2014 | 10:50 PM
jmac2354's Avatar
jmac2354
Well I finally got engine pulled and pulled the crankshaft and the reluctor wheels had in fact moved. Took crank to machine shop today. Overall I was worried about the overall engine pulling phase out the top, I had helped with initial motor swap at another guys shop with lifts. This was alot more components to take loose and more time consuming, but definately doable. Still don't understand how i get the once in a blue moon reluctor wheel that spins on the crank. I could not move it by the way, but machine shop showed me where the two wheels had moved, really crazy. Callies crankshaft reluctor came pressed on from them. There customer service explained that it was the best part available from GM and not a Callies issue, kinda sucky customer service but whatever.
Old Feb 1, 2015 | 09:55 PM
F82563's Avatar
F82563
1st Gear
Default P0335 misfire
I got this code on my 03, replaced the cps and car ran fine then warmed up ran crappy again the gave same code. I don't have headers but witing cover is brittle. Did you just repair your harness? Is there a way to test?
Thanx, KC
To P0336 Code. Video HELP
