Trans cooler line leaking
Old Sep 23, 2012 | 04:58 PM
clegg's Avatar
clegg
Default Trans cooler line leaking
Kind of hard to see but I have a trans fluid leak and its coming from the epoxy repair on the hard line right by the a/c pully bolt. Replacing the whole line looks a bit difficult, would it be feasible to cut the repaired area out and slip a rubber line on and double clamp? I took this with my phone upside down. I am guessing the PO had the line rubbing the a/c pully bolt, it began to leak and decided to use plumbing epoxy.
Old Sep 23, 2012 | 05:13 PM
lucky131969's Avatar
lucky131969
So the level of difficulty, dictates whether a correct repair is done? If that's the case, why not just take it to a trusted shop?
