So I bought a used set of wheels yesterday and will be ordering the 2" flared fenders on tuesday . My question is did I do my math correct. The wheels sIzes are as follows.
Front: 19x9.5"+57mm / 2" Deep Lip
Rear: 20x12.5"+53mm / 4" Deep Lip
I believe I would need a 1/4" spacer on the rear for the edge of the wheel to be flush with 2" flares.
My math show the rears will be 1.73 inches further out so with the 1/4 spacer this should give me the 2" out and clearance on the inside.
The fronts won't move much and I don't think that will be an issue. Please correct any of this if there is something off before Tuesday. Lol
Thanks for the in put. I did use the calculator but I was using the coupe wheels not the Z-06 wheels. Oh well I guess when I get home from my work trip ill put the new wheels on and take some real life measurements to find out the exact spacer I need. I am sure you are close from using the Z-06 wheel I came up with the 3/4" also.
