So I bought a hyperflash harness from a vendor, install went great.. Got my LEDs in today and after installing them in the front blinkers I start getting hyperflah ... I've switched the polarity and the LEDs stop working.
I've attached a video of what's going on, sorry for not holding the iPhone sideways http://www.youtube.com/watch?v=1MuxR...e_gdata_player
Any help would be great appreciated
I've never seen a hyperflash harness install cause the IPC lights to flash like that... If you remove the hyperflash harness do you still have the problem?
If no, then contact your vendor and ask for their assistance.
Thank cdk that was my next step is removing the hyper flash harness. Jw It worked fine with out the leds, I knew I shouldov bought my LEDs from you, iam a big fan of your products.
Thanks for the advice guys I'll update the thread later.
Well got some time to play with these LEDs and when the driver side led is in everything works fine, however when I install the passenger side on is when the ipc freaks out, and I did confirm that the hyperflash is plugged in all the way. For now I've went back to the old bulbs. Any one else got any suggestions ?
